Start Free TrialLog in
Avatar of burny1
burny1Flag for South Africa
Autodesk 3ds Max Design not using all processing power
Hi there,
Have a little issue. We have a workstation with the following specs: Intel i7 Lynfield, 16gig DDR3 RAM, 500gb HDD, Nvidia Quadro FX580 Screen card. OS is Win7 pro 64 and screen card driver is 266.45 - also loaded the performance drivers. The problem is that it takes almost 2 hours to do an import of a small (16MB) autocad drawing. The program only uses around 12% of the CPU power  and also seems to freeze every now and then. The total memory used never goes higher than 8GB - any idea why it does not work full steam?
Burny
Avatar of Arman Khodabande
Arman Khodabande
Flag of Iran, Islamic Republic of image
Avatar of burny1
a
