Shahid-Abbasi
Problem in load excel data into dataset using datadapet.fill method
Hi
When i load the excel data into dataset using datadapet.fill method, It shows empty cell value where invalid dates are present. I want to show the error of invalid date. kindly help to me to sort the issue.
same thing is happening while using a datareader aswell.
strange, this issue is very common, but expert team is failed to provide me the solution of this issue,
1. Read the data using DataReader
2. Try Parse your date column to valid dates, if not possible alert to the user.
