Start Free TrialLog in
Avatar of arkishor
arkishor
Same problem with the SAS Drives in DL 585G2 Shows pink led
Same problem with the SAS Drives in DL 585G2 Shows pink led no information in anyoff the HP system  management event logs or IML.
Avatar of David
David
Do a close visual inspection.   Is it possible ambient light from the adjoining light pipe is causing this?  Does the "pink" led flicker with I/O activity?   Since there is no PINK LED, and nothing in mgmt, I think it is just misaligned.
Avatar of arkishor
arkishor
Pink Light does not Flicker it is glowing steadily
and even if the take the Harddrive out of the server pink light still glows from the backpane i even tried replacing the backpane but it is still there only the last four drives rest them is fine.
Avatar of David
David
I have  Replaced the  Array Controller and  the pink lights are gone. thanks for the nailing down the issue.
Solution was very Helpful.
