nokiamobile
AT Command for "CONNECT <SPEED>" on Nokia devices
I would like t osee the connection speed when my Nokia N8 connect to internet.
Acotually when i send the command
ATD*99#
the replies with the message
CONNECT
without speed.
In attachment an example and the default settings.
How could I activate the speed in the connect message?
For example i would like to see
CONNECT 14400000 .
ATD*99#
CONNECT
without speed.
CONNECT 14400000 .
t&v
ACTIVE PROFILE:
E1 Q0 V1 X5 &C0 &D2 &S0 &Y0
+CVHU=1 +DS=0,0,2048,32 +DR=0
S00:000 S01:000 S02:043 S03:013 S04:010 S05:008 S07:060 S08:002
S10:100 S12:050 S25:002
OK
atd*99#
CONNECT
~ }#À!}!} } }2}#}$À#}!}$}%Ü}"}&} }*} } g}%~~ }#À!}!} } }2}#}$À#}!}$}%Ü}"}&} }*}
} g}%~~ }#À!}!} } }2}#}$À#}!}$}%Ü}"}&} }*} } g}%~~ }#À!}!} } }2}#}$À#}!}$}%Ü}"}&
} }*} } g}%~
which command should I use?
I already read that page, but I didn't find the correct command.
This question has been classified as abandoned and is closed as part of the Cleanup Program. See the recommendation for more details.
http://wiki.forum.nokia.com/index.php/AT_Commands
