Best way to script pulling values from SQL db, place in specific cells in spreadsheet, then get calculated values back out of excel into SQL
I've been tasked with a project to get data from a web form (done), place said data into an excel spreadsheet with extremely complex formulas set up (either directly or after being placed into a SQL database -- not done), get the resulting information from the excel spreadsheet back into another Table (not done), and then spit the result back from the SQL table into PHP (not done, but not a problem). This all needs to be done w/o intervention on the server.
Server is a Win 2k3 server running IIS 6, and will have Excel installed. Test machine is my Win7 laptop with IIS 7 and Excel installed. I have the connection to the DB set up and working properly.
I'm looking for code examples that could be used to accomplish this task. I'm not asking you to write my code for me (how would I learn from that?), but would love to see some snippets to get from A to C (SQL to Excel to SQL).
I'm not looking for Macros inside of Excel necessarily, but if this is the only way to get what I need, and it can all be scripted to launch automatically, I'm ok with it.
TimBare
TimBare
  • 5
  • 3
2 Solutions
derekkrommCommented:
You'll want to use SQL Server Integration Services
Its actually extremely easy to use. The linked article has a simple example of how to import data from Excel into SQL Server:
http://www.techrepublic.com/blog/datacenter/how-to-import-an-excel-file-into-sql-server-2005-using-integration-services/205
The reverse if essentially the same process.
TimBareAuthor Commented:
reading through the article, and i'm having some issues:
1) setting up a test spreadsheet with simple values as a proof of concept, when i set the .xls as the data source, I'm not seeing how to select a specific cell to export to the value to the DB. (all I get is columns F1 and F2).
2) i don't quite see how this is automated.
Any other documentation that you can point me to? I know I could Google it and sift through the mounds of results, but do you know of any specific articles that could help me out a bit more?
T
lcohanDatabase AnalystCommented:
This should help - once set as linked server you can run distributed queries against it:
306397 HOWTO: Use Excel with SQL Server Linked Servers and Distributed Queries
http://support.microsoft.com/kb/306397
Cloud Class® Course: Microsoft Exchange Server
The MCTS: Microsoft Exchange Server 2010 certification validates your skills in supporting the maintenance and administration of the Exchange servers in an enterprise environment. Learn everything you need to know with this course.
because my brain hurts...
In the Provider list, click Microsoft Jet 4.0 OLE DB Provider
I don't have that in my list. I do have the .dll in my syswow64 folder.
'regsvr32 msjet40.dll' gave me an error: "the module msjet40.dll failed to load..."
any thoughts? I really don't want to have to re-create all of the formulas in this spreadsheet (that tend to change, and i won't be the one that has to maintain them...) in php functions... I'll do it if I have to, but the boss really wants to see it work w/ the excel files...
So you have SQL 2005 installed on Win 64 bit OS? Sorry that wasn't explicitely mentioned and the solution works with "Excel spreadsheets - > Microsoft.Jet.OLEDB.4.0 (32-bit only)"
I think you may need to install that version and should be able to use it as documented.
http://social.msdn.microsoft.com/Forums/en/adodotnetdataproviders/thread/d5b29496-d6a1-4ecf-b1a4-5550d80b84b6
http://stackoverflow.com/questions/1991643/microsoft-jet-oledb-4-0-provider-is-not-registered-on-the-local-machine
Sorry about that. I didn't realize that 32 vs 64 bit OS made a difference for the question. I'll be more explicit from here on out.
To re-iterate what I think i'm seeing on those links, If i'm using Win7 64 bit, and office 2007, I'm out of luck. But, if I install Office 2010 and use Microsoft Access Database Engine 2010 Redistributable, I should be able to accomplish what I'm trying to do?
Again, I need to be able to pull a row from a SQL DB, and place values into specific rows on a spreadsheet, then pull different cells back out from said spreadsheet.
Thanks for the links!
Although I do not have the environment to test that at the moment with SQL 2005 that should do it. The only issue you were having was the provider that is not available for 64 bit but this workaround should provide you the suppost for your linked server. After that the queries should be the same as in the first link example except for the provider name of course but should serve your purpose. Please use a test environment first as I don't think you want to install anything directly in a production environment.
Also,
<< I need to be able to pull a row from a SQL DB, and place values into specific rows on a spreadsheet, then pull different cells back out from said spreadsheet.>>
therefor can I as why those calculations (I suppose macros in excel) cant be moved inside SQL Stored procedures if data is already in SQL? It is much more easier and faster to perform those operations plus it would save you a lots of headaches for now and the future - that's my opinion.
I the calculations aren't in the SQL database. Basically, my boss has a very complex quoting system in an excel spreadsheet with more formulas than i care to reproduce. He's already got it set up you enter a few pieces of information, and it does all of the calculations on the spreadsheet, and offers the quote.
As of now, he's sending this spreadsheet out to specific customers, allowing them to get their own quotes. However, we don't know how many times they're quoting their own projects, and therefore, we don't know which jobs we lose.
He wants to make this available online, and store the information that the client fills out in a database, so we can see which jobs we get, and which we don't.
So, the process is Web Form -> Temp SQL database -> Excel Quoter -> SQL -> webpage displaying the quote to the customer.
I know it's not the best way to do this, but we were hoping that it was something that we could throw together relatively quickly (relative to reproducing the entire quote engine in PHP) so that we could start tracking the quotes.
I suppose I could find a 32 bit machine to do this testing on, but I like my laptop as I tend to work on it from home at night, so this is the most convenient machine for development.
So, I'm trying this on my 32 bit Win 7 desktop w/ Office 07 installed. I've installed Sql Server 05, but I still don't see the Jet OLEDB 4.0 provider.
Any thoughts on getting this up and going?
Join & Write a Comment
Introducing Cloud Class® training courses
Tech changes fast. You can learn faster. That’s why we’re bringing professional training courses to Experts Exchange. With a subscription, you can access all the Cloud Class® courses to expand your education, prep for certifications, and get top-notch instructions.
  • 5
  • 3
