Can't control position of body copy and top margin in IE 7
Posted on 2011-03-08
Last Modified: 2012-06-21
Why does body copy push to the right in IE7?
How do I get site to rest at top edge of browser window in IE7?
Question by:nsitedesigns
Accepted Solution
CCSOFlag earned 1400 total points
Hmmm, try giving this CSS a 0 margin.  Not completely sure.
.twoColFixLt #sidebar1
LVL 30
Assisted Solution
LZ1 earned 600 total points
I would definitely recommend a CSS reset to start with and see if you still have the same problem.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
Join & Write a Comment
Ready to get certified? Check out some courses that help you prepare for third-party exams.
Over time, the online landscape has altered considerably, but that’s nothing compared to the up-and-coming trends that will shape the web design industry in the coming year. Keep reading to find out which trends will shape B2B web design in 2018.
The viewer will learn the basics of jQuery including how to code hide show and toggles. Reference your jQuery libraries: (CODE) Include your new external js/jQuery file: (CODE) Write your first lines of code to setup your site for jQuery…
The viewer will learn how to create a basic form using some HTML5 and PHP for later processing. Set up your basic HTML file. Open your form tag and set the method and action attributes.: (CODE) Set up your first few inputs one for the name and …
622 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
