Solved
Help needed with SQL Syntax for .CommandText using variables and literal values
Posted on 2011-03-22
5
Last Modified: 2012-05-11
Using Excel 2000 - 2003, I need help with setting the syntax used for querying a datasource (pivotTable connecting to Access Query)
As I need to convert the following SQL Strings
SELECT * FROM Query1 WHERE Query1.MyDateField BETWEEN #01/02/2009# and #28/02/2009# and Query1.TypeField ='barbecue's'
SELECT * FROM Query1 WHERE Query1.MyDateField BETWEEN #01/02/2009# and #28/02/2009# and Query1.TypeField ='Restaurant'
or I could try use:
dim Mycriteria as string
MyCriteria = "'barbecue's'"
SELECT * FROM Query1 WHERE Query1.MyDateField BETWEEN #01/02/2009# and #28/02/2009# and Query1.Type = MyCriteria
MyCriteria = "Restaurant"
But either way I need the .CommandText to accept the SQL string
Question by:Jimmy_inc
  • 3
  • 2
5 Comments
Author Comment
by:Jimmy_inc
I also meant to add that:::::::::::
I would also want to use a variable to hold the MyDateField s value , so :
e.g instead of just:
It could be
dim dtMyDatefield
dtMyDateField = MyDateField
SELECT * FROM Query1 WHERE Query1.dtMyDateField  BETWEEN #01/02/2009# and #28/02/2009# and Query1.TypeField ='barbecue's'
SELECT * FROM Query1 WHERE Query1.dtMyDateField  BETWEEN #01/02/2009# and #28/02/2009# and Query1.TypeField ='Restaurant'
or I could try use:
dim dtMyDatefield
SELECT * FROM Query1 WHERE Query1.dtMyDateField  BETWEEN #01/02/2009# and #28/02/2009# and Query1.Type = MyCriteria
LVL 61
Expert Comment
by:HainKurt
try
Query1.TypeField ='barbecue''s'
LVL 61
Expert Comment
by:HainKurt
how do you set this, or where do you put these codes?
Author Comment
by:Jimmy_inc
I'm almost inclined to delete this question but in the meantime, look at this code instead.
Dim MyCriteria as String
Dim strQueryName
strQueryName = "Query1"
.CommandText = "SELECT * FROM strQueryName WHERE strQueryName.MyDateField BETWEEN #01/02/2009# and #28/02/2009# AND strQueryName.Type = MyCriteria"
This is what I meant.
LVL 61
Accepted Solution
by:
HainKurt earned 2000 total points
try
Dim strQueryName
MyCriteria = "barbecue''s"
.CommandText = "SELECT * FROM strQueryName WHERE strQueryName.MyDateField BETWEEN #01/02/2009# and #28/02/2009# AND strQueryName.Type = '" & MyCriteria & "'"
Get 10% Off Your First Squarespace Website
Ready to showcase your work, publish content or promote your business online? With Squarespace’s award-winning templates and 24/7 customer service, getting started is simple. Head to Squarespace.com and use offer code ‘EXPERTS’ to get 10% off your first purchase.
Join & Write a Comment
A quick solution showing how to control and open a POS Cash Register Drawer using VBA with MS Access.
This following write-up describes a different way to copy Lotus Notes Calendar to Outlook. Along with this, we will also learn the reason behind this NSF to PST migration. Users can prefer different procedures as per their convenience.
With Secure Portal Encryption, the recipient is sent a link to their email address directing them to the email laundry delivery page. From there, the recipient will be required to enter a user name and password to enter the page. Once the recipient …
This lesson discusses how to use a Mainform + Subforms in Microsoft Access to find and enter data for payments on orders. The sample data comes from a custom shop that builds and sells movable storage structures that are delivered to your property. …
606 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
