I am running xp virtual machine on a mac book pro and not able to connect to internet
bjparachute
bjparachute
2 Solutions
nsx106052Commented:
Make sure the NIC is enabled on the VM.  After doing that the next step would be to check and make sure you have a valid IP address.  If there is a proxy server you will need to enter that in.
Kash2nd Line EngineerCommented:
you didn't say which VM. Normally, once in VM, you get options to use NIC as Host, Bridged mode or NAT. I have set mine to Bridged mode. then check to see if you are getting the IP allocated.
post if more issues.
Free Tool: Path Explorer
