How do I handle Many-to-Many Inserts, Updates, and Deletions with MVC 3 using Entity Framework 4 CTP5 code-first approach?
Hello Experts.  I'm getting into this MVC thing with Entity Framework and I'm loving it.  However, I've been hitting snags left and right when it comes to this many-to-many relationships.  Here you'll see the database diagram:
Database Diagramand here are the POCOs:
public class ItemCategory
    [Key]
    [ScaffoldColumn(false)]
    public int CategoryID { get; set; }
    [Required(ErrorMessage = "Please enter a name for this category")]
    public string Category { get; set; }
    [DataType(DataType.MultilineText)]
    public string Description { get; set; }
    public int? ParentCategoryID { get; set; }
    public virtual ItemCategory ParentCategory { get; set; }
    public virtual ICollection<ItemCategory> Subcategories { get; set; }
    public virtual ICollection<AuctionItem> AuctionItems { get; set; }
    public override string ToString()
        return CategoryID.ToString();
public class AuctionItem
    [Key]
    public int ItemID { get; set; }
    [Required(ErrorMessage = "Please enter a name for this item.")]
    public string ItemName { get; set; }
    [Required(ErrorMessage = "Please specify a quantity.")]
    [Range(0, int.MaxValue, ErrorMessage = "Please enter a number greater than or equal to 0.")]
    public int Quantity { get; set; }
    [Required(ErrorMessage = "Please select a company for this item.")]
    [Display(Name = "Auction Company")]
    public int CompanyID { get; set; }
    public virtual AuctionCompany AuctionCompany { get; set; }
    public virtual ICollection<ItemImage> ItemImages { get; set; }
    public virtual ICollection<ItemCategory> ItemCategories { get; set; }
    public virtual ICollection<LiveAuctionLot> LiveAuctionLots { get; set; }
        return ItemID.ToString();
public class LiveAuctionContext : DbContext
    public DbSet<AuctionItem> AuctionItems { get; set; }
    public DbSet<ItemCategory> ItemCategories { get; set; }
    // Other Entities
    protected override void OnModelCreating(System.Data.Entity.ModelConfiguration.ModelBuilder modelBuilder)
        base.OnModelCreating(modelBuilder);
        modelBuilder.Conventions.Remove<PluralizingTableNameConvention>();
        // Assists mapping because of bug
        modelBuilder.Entity<ItemCategory>().HasOptional(c => c.ParentCategory).WithMany(c => c.Subcategories).HasForeignKey(c => c.ParentCategoryID);
        // Attempt at many-to-many
        modelBuilder.Entity<AuctionItem>().HasMany(i => i.ItemCategories)
                                            .WithMany(c => c.AuctionItems)
                                            .Map(m => {
                                                        m.ToTable("ItemCategoryAssociation");
                                                        m.MapLeftKey(i => i.ItemID, "ItemID");
                                                        m.MapRightKey(c => c.CategoryID, "CategoryID");
Here's an example Create page for an Auction Item.
@model KaidAuction.Admin.UI.Models.CategoryCompanyItemViewModel
    ViewBag.Title = "Create";
<h2>Create</h2>
<script src="@Url.Content("~/Scripts/jquery.validate.min.js")" type="text/javascript"></script>
<script src="@Url.Content("~/Scripts/jquery.validate.unobtrusive.min.js")" type="text/javascript"></script>
@using (Html.BeginForm()) {
    @Html.ValidationSummary(true)
    <fieldset>
        <legend>AuctionItem</legend>
        <div class="editor-label">
            @Html.LabelFor(model => model.AuctionItem.ItemName)
        </div>
        <div class="editor-field">
            @Html.EditorFor(model => model.AuctionItem.ItemName)
            @Html.ValidationMessageFor(model => model.AuctionItem.ItemName)
        </div>
            @Html.LabelFor(model => model.AuctionItem.Description)
        </div>
            @Html.EditorFor(model => model.AuctionItem.Description)
            @Html.ValidationMessageFor(model => model.AuctionItem.Description)
        </div>
            @Html.LabelFor(model => model.AuctionItem.Quantity)
        </div>
            @Html.EditorFor(model => model.AuctionItem.Quantity)
            @Html.ValidationMessageFor(model => model.AuctionItem.Quantity)
        </div>
            @Html.LabelFor(model => model.AuctionItem.CompanyID)
        </div>
            @Html.DropDownListFor(model => model.AuctionItem.CompanyID, new SelectList(Model.Companies, "CompanyID", "Name"))
            @Html.ValidationMessageFor(model => model.AuctionItem.CompanyID)
        </div>
            @Html.LabelFor(model => model.AuctionItem.ItemCategories) (Hold Ctrl to select multiple)
        </div>
            @Html.DecodedListBoxFor(model => model.AuctionItem.ItemCategories, CategoryHelper.GetCategoriesAsListItems(Model.Categories), new Dictionary<string, object> {{ "class", "categoryList" }, {"size", "10"}}, true)
            @*@Html.ValidationMessageFor(model => model.AuctionItem.ItemCategories)*@
        </div>
        <p>
            <input type="submit" value="Create" />
        </p>
    </fieldset>
<div>
    @Html.ActionLink("Back to List", "Index")
</div>
The Html.DecodedListBoxFor is a modified version of the listboxfor I made that does not HTML Encode the text so I can allow multiple selections of the categories like so:
 DecodedListBoxForI'm passing in this viewmodel:
public class CategoryCompanyItemViewModel
    public List<ItemCategory> Categories { get; set; }
    public List<AuctionCompany> Companies { get; set; }
    public AuctionItem AuctionItem { get; set; }
and here is my controller actions for create/edit (Note that only the create works - edit returns "Invalid values '1,5,7' because of validation but inner exception shows conflicting foreign key):
public ActionResult Create()
    CategoryCompanyItemViewModel viewModel = new CategoryCompanyItemViewModel
        Categories = GetAllCategories(),
        Companies = _liveAuctionContext.AuctionCompanies.OrderBy(c => c.Name).ToList(),
        AuctionItem = new AuctionItem { Quantity = 1 }
    return View(viewModel);
[HttpPost]
public ActionResult Create(CategoryCompanyItemViewModel viewModel, FormCollection collection)
    try
        string categories = collection["AuctionItem.ItemCategories"];
        var categoryIDs = categories.Split(',');
        foreach (string categoryID in categoryIDs)
            int CategoryID = int.Parse(categoryID);
            ItemCategory category = _liveAuctionContext.ItemCategories.SingleOrDefault(c => c.CategoryID == CategoryID);
            viewModel.AuctionItem.ItemCategories.Add(category);
        _liveAuctionContext.AuctionItems.Add(viewModel.AuctionItem);
        _liveAuctionContext.SaveChanges();
        TempData["message"] = "Item created successfully.";
        return RedirectToAction("Index");
    catch
        viewModel.Categories = GetAllCategories();
        viewModel.Companies = _liveAuctionContext.AuctionCompanies.OrderBy(c => c.Name).ToList();
public ActionResult Edit(int ItemID)
    var item = from i in _liveAuctionContext.AuctionItems
                where i.ItemID == ItemID
                select i;
    if (item.Count() > 0)
            AuctionItem = item.Single()
    TempData["message"] = "That item cannot be found.";
[HttpPost]
public ActionResult Edit(CategoryCompanyItemViewModel viewModel, FormCollection collection)
    try
        _liveAuctionContext.AuctionItems.Attach(viewModel.AuctionItem);
        viewModel.AuctionItem.ItemCategories.Clear();
        _liveAuctionContext.Entry(viewModel.AuctionItem).State = EntityState.Modified;
        TempData["message"] = "Item updated successfully.";
    catch
So, what is the best way to create, update, and delete items associated with multiple categories?  Also - do I really have to query the DB and get each category and add it to the context when I create an item as I do here in my Create action?
    // get the category from the database and add to the model/context for saving
    // This seems pretty excessive/costly when the SQL way of doing it is just inserting the ID
    // into the join table
Astynax777
Astynax777
  • 2
Astynax777Author Commented:
I e-mailed Scott Guthrie and he forwarded my question on to Jeff Derstadt who was able to provide me with a solution for this.
[HttpPost]
    try
        // Retrieve the item
        var item = _liveAuctionContext.AuctionItems.Find(viewModel.AuctionItem.ItemID);
        // get the entry, so we can manipulate its state
        var itemEntry = _liveAuctionContext.Entry<AuctionItem>(item);
        // Make the entity modified
        itemEntry.State = EntityState.Modified;
        // Load the existing associated categories
        itemEntry.Collection(i => i.ItemCategories).Load();
        // Remove all the existing associated categories
        item.ItemCategories.Clear();
        // Retrieve the list of ids from the form submission (comes in comma-delimited string)
        // Split to an array
        // Iterate through each ID
            // Add Items that aren't already present
            item.ItemCategories.Add(_liveAuctionContext.ItemCategories.Find(CategoryID));
    catch
He stated:
There are a couple of important points here:
The collection must be loaded before you clear it. I cannot tell from your forum post whether that is the case or not, but I suspect not.
You should use the “Find” method on DbSet rather than using Single/SingleOrDefault since Find first looks in the local set of entities the DbContext is tracking to see if the entity is already loaded prior to going to the database.
You can use the strongly typed “Entry” method on DbContext to get a nice experience around loading a collection.
I'm asking a couple more questions so I can get a better understanding of conditional update/delete methods - which I will post here afterwards.
Sought the answer through Microsoft development team.
Join & Write a Comment
Free Tool: Site Down Detector
  • 2
