Filemaker pro 11 run a script every 60 minutes and also if it encounters an error to ignore and keep on going.
How can I have Filemaker pro 11, or Filemaker Server Advanced run a script automatically like every  hour and also have it not stop on errors?
lostinfmlandAsked:
ThomDrozCommented:
lostinfmland
In Filemaker
1) Errors can be ignored by the script step "Set Error Capture [On]"
2) Scripts can be set to a timer by the script step "Install On Timer Script"
In Filemaker Server  you can also schedule scripts to run on a schedule of your choosing
Hope that helps
TocacarCommented:
This question has been classified as abandoned and is closed as part of the Cleanup Program. See the recommendation for more details.
