[Last Call] Learn how to a build a cloud-first strategyRegister Now
Solved
Enable flash element inside WebBrowser
Posted on 2011-04-18
Last Modified: 2012-06-21
Hi. I am sending hotkeys to a flash element being loaded with WebBrowser. But for the flash element to be able to receive messages, it must first be clicked by the user. I was hoping there is a way to do this automatically, using Select(), Focus(), etc, but so far Ive had no luck.
Thank you.
Question by:JoeD77
1 Comment
LVL 10
Accepted Solution
by:
khan_webguru earned 2000 total points
Post you HTML or javascript code so that we can look into that and can suggest
We value your feedback.
Summary: This tutorial covers some basics of pointer, pointer arithmetic and function pointer. What is a pointer: A pointer is a variable which holds an address. This address might be address of another variable/address of devices/address of fu…
High user turnover can cause old/redundant user data to consume valuable space. UserResourceCleanup was developed to address this by automatically deleting user folders when the user account is deleted.
The viewer will learn how to pass data into a function in C++. This is one step further in using functions. Instead of only printing text onto the console, the function will be able to perform calculations with argumentents given by the user.
The viewer will learn how to use the return statement in functions in C++. The video will also teach the user how to pass data to a function and have the function return data back for further processing.
831 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
