Check out our new AWS podcast with Certified Expert, Phil Phillips! Listen to "How to Execute a Seamless AWS Migration" on EE or on your favorite podcast platform. Listen Now
mount the physical media tray on sever and mount remote device on another server in the same time in the same blade chassis
Last Modified: 2013-12-02
Dears,
Kindly i need explanation, if we i mount remote media or image on one of the blade servers, mount another remote media or image on another blade server and use the physical media tray on another blade server in the same time. so i could work parallel on more than one server in the same time.
thanks in advance
Ayman Mahmoud
Watch Question
Andrew Hancock (VMware vExpert PRO / EE Fellow)VMware and Virtualization Consultant
Fellow
Expert of the Year 2017
You should be able to mount remote media or images on different blades.
But if you are using phyiscal media in the cdrom, you can only use it on one blade at a time.
Danny McDanielClinical Systems Analyst
If Windows is installed on the blades, you could use magiciso to mount the .iso to a drive letter on each server.  You can use magiciso to create .iso files, too, but I believe you have to license it to create files that are over 100 mb or something like that.
Dear Hanccocka,
thanKs for your replay, and please find attached image and please tell how i can assign differant remote media or images on differnat plade server, which i just have "MOUNT REMOTE MEDIA TRAY TO: CHASSIS MEDIA TRAY OWNER" only
THANKS.
Dear Danm,
I have magiciso, i just wana know how to mout several iso in diferent blades.
note: i have IBM HS22 Blades servers
Fellow
I would recommend the use of DAEMON Tools Lite
An advanced application for Microsoft Windows which provides one of the best optical media emulation in the industry. DAEMON Tools enables you to convert your physical CD/DVD discs into "virtual discs" so called "images". It also emulated up to 4 virtual CD/DVD drives, so you can mount (insert) and unmount (eject) images.
http://www.daemon-tools.cc/eng/downloads
Download and install it on the blade servers, and then mount the iso images.
Unlock this solution and get a sample of our free trial.
(No credit card required)
UNLOCK SOLUTION
no thak u
Please provide your email to receive a sample view!
OR
Please enter a first name
Please enter a last name
