Hobart007
Using MAX function with nested AND statement within an IF statement
I am trying to write a formula in my Excel spreadsheet to perfrom the following:
For a value in column A on Sheet 1, I am trying to look up the corresponding value in a named range (column A on sheet 2) named 'NAME' and return the highest value from named range (column D on sheet 2) named 'DATE' where the parameter in named range (column B on sheet 2) named 'TYPE' is equal to ACTIVE.
Here is what I have so far:
{=MAX(IF(NAME=A2,DATE,0))}
This returns the highest value fromt he DATE range regardless of type.
The change I tried to make is as follows:
{=MAX(IF(AND(NAME=A2,TYPE= "ACTIVE"), DATE,0))}
This returns a value of zero rather than the highest value int he DATE range where NAME = A2 and TYPE = ACTIVE.
Can someone help me with what I am doing wrong?
Array formulas are more CPU intensive than other formulas, but a few hundred should not affect the performance of your system. And they should most definitely not cause Excel or Windows to crash. Might be time to rebuild.
Kevin
Kevin
Is there a less system intensive way to do this?
