I can not find the position of the power led, power sw , led hd ?
Hello Expert , I had a problem starting the desk top , I can not figure out the position of power sw ,hd led ,and the rest , there is a diagram but not sure how to plug them , its used to start ok , I just cleaned it from dust and forgot the positions and kept trying for hours with no luck , pls if possible with pic , that would be gr8
hnaelAsked:
ryan_johnstonCommented:
It all depends on the motherboard.  They are in all kinds of different places on different manufacturers.  They are usually color coded.
hnaelAuthor Commented:
I can see that , and thats my question , where can I find the mobo descreption ? I can see the lables but find it hard to follow
Improved Protection from Phishing Attacks
WatchGuard DNSWatch reduces malware infections by detecting and blocking malicious DNS requests, improving your ability to protect employees from phishing attacks. Learn more about our newest service included in Total Security Suite today!
Written somewhere on the motherboard is the make and model of it.  If you can find that, I might be able to find out.  Just need a little more info.
Usually the speaker is red and black and it 4 pins wide, the reset switch is 3 pins wide, the power switch, power led, and hdd led (if avail) will all be 2 pins.
thks, I could see they r written on mobo , but I need photo of where each cable belong , I find it so difficult to put them right .sorry , its intel mobo
its intel lga 775
Do you know the model of the intel mobo?
K, let me look it up.
lga 775 is the socket, not the model
ok, btcr 7240174k   AA D78647-304 IS IT THIS ONE
Now the cables r like this reset sw white and obagine h.d.d led black and red  power sw white and red and then tow single cable with one pin each one is green colour and one is white , thats all the cable I need to connect .
dbruntonCommented:
Carrying on from ryan_johnston's comment.
Look for a series of letters and numbers.  That'll be the motherboard model number which you can Google and find the manufacturer's manual.
Also see http://www.formfactors.org/developer%5Cspecs%5CA2928604.pdf and pages 17 and 18 which might be of use if the board uses standard Intel connectors.
Oh by they my understanding if I mix up cables does not kill the mobo or does it ?
See if this will help you:
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
Btw, your MB is an Intel D945GCCR
dbruntonCommented:
Rayan you r right , I saw this no D945GCCR , IF I connect them wrong will that kill the mobo ,
No, it just won't work.
Rayn , I saw the pic, when it says out , does this means the writien on the wire should fase outside , also how will I know pin 1 or 2 or whatever ?
It doesn't matter about the numbers in the pictures. Thats just telling you which pins are what.  Just put the cables on the the writing facing out.
ok , but what I gt is like this power sw(red/white )2 pins , reset sw (obagine/white) 2 pins , h.d.d led(black /red) 2 pins and then one white & green cable with one pin each , so I gt total 8 but in the pic it should be 9 !!! is there a way to gt the manual pls
In the picture I showed you...you don't need pin 9.  Hell, you don't even need any of them plugged in except the power switch. If you have just the power switch plugged in and nothing else, it would still turn on.
Calm down mate , I can understand ur frustration , but thks anyway , I want ask any further , point is urs .
I'm not getting frustrated, just saying that those aren't a huge deal to where if you plug the wrong one in, thats it's going to fry your computer.  It simply won't work, then you try again, and repeat til it works.  If it doesn't work and they are plugged in properly then you may have an additional hardware issue such as a bad Power Supply or bad Motherboard, etc.
dbruntonCommented:
As long as you get the right pair of wires to the right pair of pins there is no problem.
For example you can get the power switch wires around the wrong way and it will still work.  White is usually the ground wire.
You've got two LED connections there.  If the lights don't work then reverse the connection and they should then then work.  Being round the wrong way won't harm them.
But just get the right pair to the right pins and you'll be OK.
thks
