Solved
Solaris System System checks for Applications and Databases
Posted on 2011-05-04
Last Modified: 2013-12-27
Hi Experts. What are the assessments/checks to do from the Solaris side for a Databases and Applications GOLIVE. We want to make sure the settinsg stay the same if the server reboots. There are a few clusters as well.
Question by:Rhiaanon44
2 Comments
LVL 81
Accepted Solution
by:
arnold earned 2000 total points
make sure that the services (svcadm) are configured to start at boot.
Check that the mount points are configured for mounting /etc/vfstab etc.
Make sure that your networking components are configured versus you had to manually bring them up using ifconfig.
Presumably during the setup/configuration the systems were rebooted and came back.
Author Closing Comment
by:Rhiaanon44
tHANK YOU!
Add Premium security features to your question to ensure its privacy or anonymity. Learn more about your ability to control Question Security today.
I promised to write further about my project, and here I am.  First, I needed to setup the Primary Server.  You can read how in this article: Setup FreeBSD Server with full HDD encryption (http://www.experts-exchange.com/OS/Unix/BSD/FreeBSD/A_3660-S…
Using libpcap/Jpcap to capture and send packets on Solaris version (10/11) Library used: 1.      Libpcap (http://www.tcpdump.org) Version 1.2 2.      Jpcap(http://netresearch.ics.uci.edu/kfujii/Jpcap/doc/index.html) Version 0.6 Prerequisite: 1.      GCC …
Learn how to find files with the shell using the find and locate commands. Use locate to find a needle in a haystack.: With locate, check if the file still exists.: Use find to get the actual location of the file.:
This video shows how to set up a shell script to accept a positional parameter when called, pass that to a SQL script, accept the output from the statement back and then manipulate it in the Shell.
Suggested Courses
Course of the Month13 days, 20 hours left to enroll
809 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
