[Last Call] Learn how to a build a cloud-first strategyRegister Now
Remote System Explorer Problem
Hi experts...
I have installed the remote system explorer in eclipse europa.
It works fine but in ftp mode i am able to traverse down my home directory but not upwards.
Please can any one suggest any methods to traverse up the directory or change the home directory to only root i.e "/".
gaugeta
gaugeta
  • 6
  • 5
  • 4
cmalakarCommented:
FTP wont allow you to go up.
It starts from the logged in users home directory and traverse down.
CEHJCommented:
Probably because the ftp server is restricting access to anything else (as it normally should)
gaugetaAuthor Commented:
@cmalakar & @CEHJ: So how do traverse up all my files are above this directory.
Please suggest any alternative all my files are above this directory.
Please help...
We value your feedback.
CEHJCommented:
You'll have to reconfigure at the server itself
cmalakarCommented:
Depending on the FTP Server, the configuration will differ.
But in ssh mode i can access my / directory but it is so slow that just to expand a folder it takes a lot of time.
cmalakarCommented:
yes, ssh it will allow you to traverse, if the logged in user has the permission set.
CEHJCommented:
You might find it quicker to use locate from the root path
No its extremely slow and hangs around 95% of the time.
Please help...
cmalakarCommented:
If you think FTP is fast enough, you may want to configure server, to take the logged in home directory to "/" instead of any other.
@cmalakar:What if we dont have permissions to configure the server.Is any alternative present?
Please help...
CEHJCommented:
If you're talking about locate, then it sounds like you have quite different (or additional) problems
cmalakarCommented:
did you try with latest versions of eclipse ?
@cmalakar:I use eclipse europa.
Please help.
cmalakarCommented:
Eclipse Europa is a 4 years old release of eclipse.
Try eclipse Helios.
  • 6
  • 5
  • 4
