rogue028
Monitor won't display on anything larger than 17" monitor
I have an odd situation. I have a computer with a Nvidia GEforce 7300GS video card in it. It was attached to a 23" Westinghouse monitor and after a thunderstorm it quit displaying. I can attach it to a 17" monitor and it displays fine. I have swapped video cards, I have swapped monitors and I can't figure out why it will not display. I even put a different 23" monitor on it and it will not display. I can connect it back to the 17" monitor and it will be fine. I have changed the refresh rate and it has not helped. Any ideas?
I am assume you have change the resolution too?
The monitor is capable of both VGA and DVI and so is the card. I have tried both on the 23" and nothing works. The monitor doesn't ever show anything on the display. Yes, I have changed the resolution also.
If everything was working fine before the thunderstorm and now it doesn't, I think your card suffered from an induced voltage spike which has damaged the card. Replace the card.
Tried replacing the video card with both a PCI and another PCIe card but nothing. I think I'm just going to ditch the PC.
Are you using VGA on 17 inch monitor and DVI on the other monitors... or vice versa? If so you may have to change a display setting in the bios to use the other display. It's pcould be the aspect ratio that is the problem, connect the 23 inch monitor and see if it will display in safe mode.
