mickeyshelley1
Problem Running VBA Code after Reloading Operating System.
Windows 7 Home Premium
Access 2003
I have recently re formatted and reinstalled office 2003 and since then I get the following error when ever i attempt to run any vba code i.e. to close a form, to open another form, to save a record, or simply go to a new record.
The expression On Click you entered as the event property setting produced the following error: A problem occured while Microsoft Office Access was communicating with the OLE server or ActiveX Control.
this is an example of vba code i have on a button to save current record and go to a new record.
Private Sub Command12_Click()
If Me.Dirty Then Me.Dirty = False
DoCmd.GoToRecord , , acNewRec
End Sub
Access 2003
End Sub
The database in question works fine on others computers, it worked fine on this computer until it crashed and I had to do a reinstall. I checked the references and didn’t find any “missing” so I am at a loss..
Well your using DAO, so go ahead and re-register that (won't hurt):
1. Drop to a command prompt.
2. CD to Windows\system32
3. Type
Regsvr32 "<path to the DAO DLL>"
usually it's
regsvr32 "c:\program files\common files\microsoft shared\dao\dao360.dll"
But check the path in the reference dialog.
Also, did you follow the reference refresh procedure I gave in my first comment?
JimD.
3. Type
usually it's
JimD.
I moved everything into a new blank database which corrected the issue.
Then do a compile. If no errors, you should be set. If not, you either:
a. need to add a reference that the app needs
b. Need to re-register DAO if your using it.
c. Need to either decompile or create a fresh DB as you might have some VBA project corruption.
Bounce back and let me know...
JimD.
