Is it possible to create a VLAN using Cisco 1841 built in Ethernet port & a 4 port Cisco Etherswitch HWIC module?
We plan to upgrade our sonicwall firewall to HA failover which has ad additional standby device.
Currently the single sonicwall is connected to my Internet router (cisco 1841) using its built in ethernet port.
When i introduce the second standy sonicwall i will also need to conenct this to the router but
I don't want to add a switch.
My Idea is to add a 4 port switch module to the cisco & then create a VLAN to include the 4 switch ports & built in ethernet port.
Does any one know if is possible & will work?
esitrepxe
esitrepxe
  • 3
  • 2
  • 2
  • +1
2 Solutions
Andrew Hancock (VMware vExpert / EE MVE^2)VMware and Virtualization ConsultantCommented:
yes, you can create and add vlans to vmware esx server.
esitrepxeAuthor Commented:
This question has nothing to do with vmware
The vmware zone has been added by mistake
Rewarding opportunities for women in IT
Across the nation, technology jobs are vacant because there aren’t enough qualified professionals to fill them. With a degree from WGU, you can get the credentials it takes to become an in-demand IT professional. Plus, WGU’s IT programs include industry certifications.
oh dear!
rfc1180Commented:
No, it is not possible; you can not add the built-in ethernet port to a vlan, it is a fixed layer 3 interface.
Billy
Thanks for answer Billy.
If i just add the 4 port switch module & create a VLAN just using its ports. Am I right in thinking
I can move the IP from the current onboard to the vlan & do it that way instead?
rfc1180Commented:
Yes, you can create a vlan interface and move the IP over.
Billy
QlemoC++ DeveloperCommented:
This question has been classified as abandoned and is closed as part of the Cleanup Program. See the recommendation for more details.
NFR key for Veeam Agent for Linux
Veeam is happy to provide a free NFR license for one year.  It allows for the non‑production use and valid for five workstations and two servers. Veeam Agent for Linux is a simple backup tool for your Linux installations, both on‑premises and in the public cloud.
  • 3
  • 2
  • 2
  • +1
