What is difference between string and String? same way int and Int16,32,64 etc
I know in C# we have both variable type like string and int and then object type with CAPS like Int32 and String.
I know one is primitive variable and the other is a class object but as a newbie I just look at it as a concept. Can you give me any specific scenario in which we use use one over other and why?
TheCommunicatorAsked:
Jens FiedererConnect With a Mentor Test Developer/ValidatorCommented:
The Int16, etc. allow you to specify the number of bits - only ONE of these is the same as int.
Not much difference aside from style between string and String, see
http://stackoverflow.com/questions/215255/string-vs-string-in-c
TheCommunicatorAuthor Commented:
Thank you so much :).
Jens FiedererTest Developer/ValidatorCommented:
My pleasure, thanks.
mrjoltcolaCommented:
In C# there isn't any difference. One is a compiler alias to the other.
