[Okta Webinar] Learn how to a build a cloud-first strategyRegister Now
Solved
How do I code a statement in sql with a more than, less than and equal to?
Posted on 2011-05-12
Last Modified: 2013-12-07
How would I code this:
How many states start with the letter “N”? Are the number of states that start with the
            letter “N” more than, less than or equal to the states that starts with the letter “M”?
Question by:KayMJay
  • 2
2 Comments
LVL 74
Accepted Solution
by:
sdstuber earned 2000 total points
select count(case when state_name like 'N%' then 1 end) Ncount,
count(case when state_name like 'M%' then 1 end) Mcount
from states
LVL 74
Expert Comment
by:sdstuber
you can either return the results "as is", or if you want to include the more/less/equal evaluation in the results then put another case that checks the results of the counts and displays whatever message you want
We value your feedback.
Using SQL Scripts we can save all the SQL queries as files that we use very frequently on our database later point of time. This is one of the feature present under SQL Workshop in Oracle Application Express.
When it comes to protecting Oracle Database servers and systems, there are a ton of myths out there. Here are the most common.
This video shows, step by step, how to configure Oracle Heterogeneous Services via the Generic Gateway Agent in order to make a connection from an Oracle session and access a remote SQL Server database table.
This video explains what a user managed backup is and shows how to take one, providing a couple of simple example scripts.
Suggested Courses
872 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
