Avatar of shambalad
shambalad
Problem with Drag-N-Dropper - Drop Control not found
I have just started working with the Drag-N-Dropper package from Peters Software (pretty amazing stuff. BTW).
I am trying to drag a record from one continuous subform to a field on another continuous subform, both of which are on the same form. Everything seems to be working OK, except that the “Drop Control” is not being found. Actually what happens is the process defaults to the last control on the continuous subform, rather than the actual control the 'MouseUp' is being executed over. I am hoping someone may have some hints on why this might be. Any help offered would be most appreciated.
I am working in Access 2007.
Tod
Microsoft Access
shambalad
