mhwolog
Having trouble finding required specs for replacement power supply
Hello, I have an pentium 4 Acer Power series f5 tower which I need a new power supply for. The existing power supply is 15cm X 14cm X 8.5 cm and has a 24pin connection (model FSP300-60THA(1) 300W). The motherboard is ECS - RC410 M2 http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=589&CategoryID=1&MenuID=16&LanID=9.
The PC is just running the standard graphics card etc, no upgrades. Not used for gaming.
Are there any special specifications I need to find in a new power supply? - the mobo specs don't seem to give detailed info.
I also have another used power supply which is the same size, but only has a 20 pin connection and is 450 W (Eagle model no DR - B450E). Can this be used temporarily or permanently? - the PC works when this is plugged in, but some of the output amps are slightly different.
sorry - ideally you would want the 24 pin connector, but the extra pins are to supply extra current (Amps) if required - which is somewhat unlikely uless you put more cards in
If I was to buy a new one, does the fan need to be facing exactly the same direction? The existing one had a ~7cm fan facing out the back of the tower.
Does brand matter for general use/lower end wattage uses?
Well every PSU I ever bought had a fan blowing out the back. Brand doesn't matter as much on a basic low end PC but I wouldn't buy one from the Dollar Store either...no matter the system.
you can use a 20 to 24 pin adapter : http://www.xoxide.com/20-to-24-pin-adapter.html
Thanks guys
