troubleshooting Question
Split string into 3 parts in Oracle
Avatar of skahlert2010
skahlert2010 asked on
Oracle DatabaseSQL
7 Comments1 Solution833 ViewsLast Modified:
Hello experts!
I need to split one string into 3 parts i.e. firstname, surname and degree.
While I am able to split into first and surname, I cannot extract the degree if there's one mentioned.
The strings to be split apart come in the following way:
Dr. James Example
Could you please assist me in splitting this string apart into three parts?
A million thanks in advance! I am curious about your appraches!
My current code is attached below. p_username is a parameter passed to the procedure!
select secondname || '\, ' || firstname || ' (LWF)' into ad_name from (
select substr(replace(p_username,',',''), 1, (instr (replace(p_username,',',''), ' ') - 1)) as firstname,
substr (replace(p_username,',',''), (instr (replace(p_username,',',''), ' ',1,1) + 1), length (replace(p_username,',',''))) as secondname
from dual);
Unlock 1 Answer and 7 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
