Sound Card Audigy - Hardware Problem
I have bought a new sound card Creative Audigy and when I install the drivers the Blue Screen of Death comes on the screen and the PC re-boots by itself. When OS restarts, the OS says Windows Encountered a Serious etc....
The motherboard is malfunctioning?
David CamilleriAsked:
joshbulaConnect With a Mentor Commented:
If you are installing drivers from the CD, check the Creative website for updated drivers and firmware.
If the "Windows Encountered A Serious Error" happens every time you try to boot, even in safe mode, then it probably is a hardware problem with either the sound card or the motherboard.
Possibly, check your motherboard manufacturer for firmware or bios updates.
nobusCommented:
it could be a bad card DOA
you can test it in another PC, or in another slot
can your Power supply handle the load?  calculate it here : http://www.antec.outervision.com/
or just test with a beefier PS
you can also post the minidump here (from windows\minidumps) for more info
David CamilleriAuthor Commented:
Update of software what was needed. Thanks.
