How do I change the battery power plan while using a "desktop"
I’m building a Windows 7 Pro 32-Bit SP1 image and I’m using a Virtual Machine (VMWare VSphere) to accomplish that. I’m trying to adjust power settings and I can for the desktop but I have no option to adjust them for battery or Laptop.
I’m trying to figure out a way to modify battery power plan settings even that Windows does not see that I have a battery.
Any help would be appreciated.
SRCL
SRCL
3 Solutions
shbasmCommented:
it is better to make two images one for desktops and one for laptops
johnb6767Commented:
If you are going to consider making a single image, then look at using GPO/Startup/Logon Scripts to mange Power Options.....
PhilonatorownerCommented:
Power is controlled in 2 spots on windows 7-
-Group policy where johnb6767 described
-local client machine, control panel, power.
johnb6767Commented:
To elaborate....
Start/Logon scripts, could use powercfg.exe to set these , and in the sxcript have it detect desktop/laptop, and set accordingly....
LeeTutorretiredCommented:
This question has been classified as abandoned and is closed as part of the Cleanup Program. See the recommendation for more details.
[Webinar] Kill tickets & tabs using PowerShell
Are you tired of cycling through the same browser tabs everyday to close the same repetitive tickets? In this webinar JumpCloud will show how you can leverage RESTful APIs to build your own PowerShell modules to kill tickets & tabs using the PowerShell command Invoke-RestMethod.
