ASP.NET 4.0 web page moved from web site to web project doesn't work
Hello experts,
I have a "web site" that I created in Visual Studio that I want to convert into a "web project" in Visual Studio 2010. I created the "web project" in a new location and then moved my .aspx and .aspx.cs files into that new location and added them/included into my project from Visual Studio and set it as my start page.
The problem is that the controls on the aspx page (for example: lblUploadStatus) are not recognized from my .cs page. I'm getting "The name lblUploadStatus does not exist in the current context."
Does anyone know how to fix? I was working fine in my "web site". Also I noticed that I don't have a .aspx.designer.cs file. Is that part of the problem? Thanks. error message screen shot
dpicco
dpicco
Ajay SharmaCommented:
Ramkisan JagtapLead DeveloperCommented:
I faced the same problem some time before. Only solution I fould at that time was to create new pages in new web project and then copy paste the code  from old pages to new pages. Actully its irritating process if you have too many files to add. But you can give a try. I don't know if there is a valid process suported by visual studio.
Regards,
Ram
tovvenkiCommented:
what happens when you try to build/rebuild the project?
Regards,
Venki
dpiccoAuthor Commented:
Thanks. I just had to right click on each file inside VS2010 and convert to web application
After selecting convert to web application, VS2010 will recreate the designer.cs file for you.
VIDEO: THE CONCERTO CLOUD FOR HEALTHCARE
Modern healthcare requires a modern cloud. View this brief video to understand how the Concerto Cloud for Healthcare can help your organization.
