Solved
How to run sql or pl/sql block using shell script?
Posted on 2011-09-20
5
Last Modified: 2012-05-12
I am running simple sql query using shell script and store the result in a variable. I ran the below code but result is not storing in the output. Please advise.
# Oracle Environment Variables
. $HOME/.profile
ORA_USER=user
ORA_PWD=password
# Local Variables
run_date=`date '+%Y%m%d'`
run_time=`date '+%H%M%S'`
shell_dir=$HOME/analytics/bin
sql_dir=$HOME/analytics/sql
tmp_dir=$HOME/analytics/tmp
log_dir=$HOME/analytics/log
progName=${0##*/}
sql_file=${sql_dir}/${progName%%.*}.sql
tmp_file1=${tmp_dir}/${progName%%.*}_${run_date}${run_time}.1.sql
tmp_file2=${tmp_dir}/${progName%%.*}_${run_date}${run_time}.2.sql
log_file=${log_dir}/${progName%%.*}_${run_date}${run_time}.log
start_time=`date +%Y-%m-%d-%H:%M:%S`
echo "Sample script is started at $start_time." >> ${log_file}
cat <<- EOF > $tmp_file1
set echo off;
set term off;
set heading off;
set feedback off;
whenever sqlerror exit;
select sysdate
from dual;
exit;
EOF
seg_snap_date=$(sqlplus ${ORA_USER}/${ORA_PWD}@DATABASE @$tmp_file1) >> ${log_file}
echo "Today's date $seg_snap_date" >> ${log_file}
cat $log_file
exit $?
Question by:IT_ETL
  • 2
  • 2
5 Comments
LVL 15
Assisted Solution
by:Devinder Singh Virdi
Devinder Singh Virdi earned 800 total points
Use Method 1
var= `sqlplus -s username/pass@db @file_to_execute.sql`
Method 2:
sqlplus -L -silent username/pass@db |&
print -p -- 'set feed off pause off pages 0 head off veri off line 500'
print -p -- 'set term off time off'
print -p -- " set sqlprompt '' "
print -p -- "select sysdate from dua;"
read -p ORACLE_DT
# YOU CAN USE UNIX COMMAND HERE
print -p exit ;
Author Comment
by:IT_ETL
I have modified above code as you suggested below. But still result from sql block is not stored in the variable.
set echo off
set term off
set heading off
set feedback off
select sysdate
from dual;
exit;
EOF
seg_snap_date=`sqlplus -s ${ORA_USER}/${ORA_PWD}@ADWPRD @$tmp_file1`
LVL 78
Accepted Solution
by:
slightwv (䄆 Netminder) earned 1200 total points
Try this:
set term on
Author Comment
by:IT_ETL
Thanks slightwv! It worked.
LVL 78
Expert Comment
by:slightwv (䄆 Netminder)
Glad to help.  did you go back and try your original code?  My shell scripting is rusty but it should work as well.
Get your problem seen by more experts
Be seen. Boost your question’s priority for more expert views and faster solutions
How to Create User-Defined Aggregates in Oracle Before we begin creating these things, what are user-defined aggregates?  They are a feature introduced in Oracle 9i that allows a developer to create his or her own functions like "SUM", "AVG", and…
When it comes to protecting Oracle Database servers and systems, there are a ton of myths out there. Here are the most common.
Video by: Steve
Using examples as well as descriptions, step through each of the common simple join types, explaining differences in syntax, differences in expected outputs and showing how the queries run along with the actual outputs based upon a simple set of dem…
This videos aims to give the viewer a basic demonstration of how a user can query current session information by using the SYS_CONTEXT function
Suggested Courses
601 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
