how to extract specific parts of text from an XML element
Guess this a  tricky one.
In the xml below I have elements like this &alt; href="somelink">Cardiovascular disease,unspecified&alt;/a> some stull &alt; href="somelink">Aspirin&alt;/a>
I need to concatenate entries present as a href text sepearted by semicolon. e.g.
Cardiovascular disease,unspecified;Aspirin
Also any duplicate entries must be removed.
<element name="msubjectgen">
			<value>
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl00_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;ICD9CM&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Cardiovascular+disease%2c+unspecified &amp;umls=1'&gt;Cardiovascular disease, unspecified&lt;/a&gt; (429.2)
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl02_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MSH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases &amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention &amp;umls=1'&gt;Chemoprevention&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Patient+Education+as+Topic &amp;umls=1'&gt;Patient Education as Topic&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl04_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MTH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases &amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention &amp;umls=1'&gt;Chemoprevention&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Patient+education+(procedure) &amp;umls=1'&gt;Patient education (procedure)&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl06_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;PDQ&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=acetylsalicyclic+acid &amp;umls=1'&gt;acetylsalicyclic acid&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl08_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;SNOMEDCT&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt; (387458008); &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt; (7947003); &lt;a href='/search/search.aspx?term=Aspirin+prophylaxis &amp;umls=1'&gt;Aspirin prophylaxis&lt;/a&gt; (312452009); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system &amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (105980002); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system &amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (49601007); &lt;a href='/search/search.aspx?term=Patient+education &amp;umls=1'&gt;Patient education&lt;/a&gt; (311401005); &lt;a href='/search/search.aspx?term=Prophylactic+chemotherapy &amp;umls=1'&gt;Prophylactic chemotherapy&lt;/a&gt; (268500004); &lt;a href='/search/search.aspx?term=Taking+aspirin+education &amp;umls=1'&gt;Taking aspirin education&lt;/a&gt; (315045009)
                                </value>
		</element>
mmalik15Asked:
Geert BormansConnect With a Mentor Information ArchitectCommented:
well, this matter is complex enough to try to migrate to XSLT2
There IS a version of XSLT2 for .net, if you would install Saxon .net www.saxonica.com
But at the heart of it, I think you need to change your crawler.
I have done my share of building webcrawlers and I was always most succesful if I did this
- fetch the page directly through the url
- run it through TagSoup (XHTMLTidy would work as well) resulting in a well-formed XHTML
- have my XSLT filter on the XHTML to get the data I needed
Then you don't need complex text processing, but you can simply use the structure.
So, my first advice: there is something fundamentaly wrong with your crawler methodology. Fix that first, and see what comes out next,
before you start this very complex xslt1 text processing adventure (which I strongly recommend you would avoid)
Geert BormansInformation ArchitectCommented:
Yes, this is a tricky one indeed.
Something that used to be XML has been slammed down to a pure text node
so you are up to text processing
Given your other questions, I guess you need an XSLT solution?
Can this be XSLT2? or do you need XSLT1
XSLT1 will be very hard and the uniqueness constraint will require a second pass I am afraid
If you need XSLT1, can you tell me how you perform the XSLT (which code and which processor)
could you manage a second pass?
mmalik15Author Commented:
Actually I am crawling a website and getting this information from there. To extract this information from a webpage using regular expressions was impossible so I have it now in xml and need to use xslt 1.0( as .net only supports 1.0) to extract parts of the data. The xml that i have will use xslt to transform into refined xml and then this xml will be dumped into our database.
Get expert help—faster!
Thanks for the suggestion Gertone. I will into the details of that.
I hvae tried the attached xslt and stripped the html tags and my out put element becomes like this
<element name="msubjectgen"><value>
                                            ICD9CM:
                                            , unspecified (429.2)
                                            MSH:
                                            Aspirin; Cardiovascular Diseases; Chemoprevention; Patient Education as Topic
                                            MTH:
                                            Aspirin; Cardiovascular Diseases; Chemoprevention; Patient education (procedure)
                                            PDQ:
                                            SNOMEDCT:
                                            Aspirin (387458008); Aspirin (7947003); Aspirin prophylaxis (312452009); Disorder of cardiovascular system (105980002); Disorder of cardiovascular system (49601007); Patient education (311401005); Prophylactic chemotherapy (268500004); Taking aspirin education (315045009)
                                </value></element>
Now can we possibly concatenate values present after MSH:, MTH: and SNOMEDCT: and remove the duplicates
I have also attached my xml and the style sheet i have used
<?xml version="1.0" encoding="ISO-8859-1"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
                  version="1.0">
	<xsl:template name="strip-tags">
		<xsl:param name="text"/>
		<xsl:choose>
			<xsl:when test="contains($text, '&lt;')">
				<xsl:value-of select="substring-before($text, '&lt;')"/>
				<xsl:call-template name="strip-tags">
					<xsl:with-param name="text" select="substring-after($text, '&gt;')"/>
				</xsl:call-template>
			</xsl:when>
			<xsl:otherwise>
				<xsl:value-of select="$text"/>
			</xsl:otherwise>
		</xsl:choose>
	</xsl:template>
	<xsl:template name="strip-roundbrackets">
		<xsl:choose>
			<xsl:when test="contains($text, '(')">
				<xsl:value-of select="substring-before($text, '(')"/>
					<xsl:with-param name="text" select="substring-after($text, ')')"/>
			</xsl:when>
			<xsl:otherwise>
			</xsl:otherwise>
		</xsl:choose>
	</xsl:template>
	<xsl:template match="@*|node()">
		<xsl:copy>
			<xsl:apply-templates select="@*|node()"/>
		</xsl:copy>
	</xsl:template>
	<xsl:template match="//document/element[@name='body']/value/node()">
			<xsl:with-param name="text" select="."/>
	</xsl:template>
	<xsl:template match="//document/element[@name='teaser']/value/node()">
	</xsl:template>
	<xsl:template match="//document/element[@name='msubjectgen']/value/text()">
		<!--<xsl:choose>
			<xsl:when test="//document/element[@name='mrtype']/value/text()='Systematic Review'">
				<xsl:value-of select="translate(.,',',';')"/>
			</xsl:when>
			<xsl:when test="//document/element[@name='mrtype']/value/text()='Evidence Summary'">
				<xsl:value-of select="translate(.,':',';')"/>
			</xsl:when>
			<xsl:when test="//document/element[@name='mrtype']/value/text()='Measure'">
				<xsl:call-template name="strip-roundbrackets">
			</xsl:when>
		</xsl:choose>-->
	</xsl:template>
	<xsl:template match="//document/element[@name='mauthororganisations']/value/node()">
			<xsl:with-param name="text" select="translate(.,'-',';')"/>
	</xsl:template>
</xsl:stylesheet>
<?xml version="1.0" encoding="utf-8"?>
<documents>
	<document id="http://www.qualitymeasures.ahrq.gov/content.aspx?id=32558">
		<element name="body">
			<value>&lt;p&gt;This measure uses survey data to assess the percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.&lt;/p&gt;</value>
		</element>
		<element name="html">
			<value>&lt;html&gt;&lt;head&gt;&lt;meta name=&quot;keywords&quot; content=&quot;insert keywords here&quot; /&gt;&lt;meta name=&quot;description&quot; content=&quot;Aspirin use: percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.&quot; /&gt;&lt;title&gt;
	National Quality Measures Clearinghouse | Aspirin use: percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.
&lt;/title&gt;&lt;/head&gt;&lt;body&gt;&lt;div class=&quot;padding content_page&quot;&gt;
        &lt;div style=&quot;float:left; width:500px;&quot; class=&quot;accent_color bigger_bold&quot;&gt;
            &lt;span id=&quot;ctl00_ContentPlaceHolder1_lblTitleType&quot;&gt;Measure&lt;/span&gt; Summary
        &lt;/div&gt;
        &lt;div style=&quot;margin-left:200px; text-align:right;&quot;&gt;
            &lt;img src=&quot;images/icon_print.gif&quot; alt=&quot;&quot; style=&quot;margin-right:5px;&quot; /&gt;&lt;a id=&quot;ctl00_ContentPlaceHolder1_hlPrint&quot; href=&quot;javascript:LaunchPrintView(32558);&quot;&gt;Print&lt;/a&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&lt;b&gt;Download as:&lt;/b&gt; &lt;a onclick=&quot;dcsMultiTrack('DCS.dcsuri', '/content/download/PDF','WT.ti', 'Content%20Page%20|%20Download%20|%20PDF');&quot; id=&quot;ctl00_ContentPlaceHolder1_lbPDFDownload&quot; href=&quot;javascript:__doPostBack('ctl00$ContentPlaceHolder1$lbPDFDownload','')&quot;&gt;PDF&lt;/a&gt; (&lt;a href=&quot;/disclaimer.aspx?redirect=http://get.adobe.com/reader/&quot;&gt;Adobe Reader&lt;/a&gt; &lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot;/&gt;) | &lt;a onclick=&quot;dcsMultiTrack('DCS.dcsuri', '/content/download/Word','WT.ti', 'Content%20Page%20|%20Download%20|%20Word');&quot; id=&quot;ctl00_ContentPlaceHolder1_lbWordDownload&quot; href=&quot;javascript:__doPostBack('ctl00$ContentPlaceHolder1$lbWordDownload','')&quot;&gt;Word&lt;/a&gt; | &lt;a onclick=&quot;dcsMultiTrack('DCS.dcsuri', '/content/download/HTML','WT.ti', 'Content%20Page%20|%20Download%20|%20HTML');&quot; id=&quot;ctl00_ContentPlaceHolder1_lbHTMLDownload&quot; href=&quot;javascript:__doPostBack('ctl00$ContentPlaceHolder1$lbHTMLDownload','')&quot;&gt;HTML&lt;/a&gt; | &lt;a onclick=&quot;dcsMultiTrack('DCS.dcsuri', '/content/download/XML','WT.ti', 'Content%20Page%20|%20Download%20|%20XML');&quot; id=&quot;ctl00_ContentPlaceHolder1_lbXMLDownload&quot; href=&quot;javascript:__doPostBack('ctl00$ContentPlaceHolder1$lbXMLDownload','')&quot;&gt;XML&lt;/a&gt;
            &lt;span id=&quot;ctl00_ContentPlaceHolder1_lblExport&quot;&gt;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&amp;nbsp;&lt;b&gt;Export to: &lt;/b&gt;&lt;/span&gt;
            &lt;a onclick=&quot;dcsMultiTrack('DCS.dcsuri', '/content/download/ENDNOTE','WT.ti', 'Content%20Page%20|%20Download%20|%20ENDNOTE');&quot; id=&quot;ctl00_ContentPlaceHolder1_lbCitManager&quot; href=&quot;javascript:__doPostBack('ctl00$ContentPlaceHolder1$lbCitManager','')&quot;&gt;Citation Manager&lt;/a&gt;
        &lt;/div&gt;
        &lt;div class=&quot;content_spacer_top&quot;&gt;&lt;img src=&quot;images/spacer.gif&quot; style=&quot;height:1px;&quot; alt=&quot;&quot; /&gt;&lt;/div&gt;
         &lt;table id=&quot;ctl00_ContentPlaceHolder1_dlXML&quot; cellspacing=&quot;0&quot; border=&quot;0&quot;&gt;
	&lt;tr&gt;
		&lt;td&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field11'&gt;&lt;/a&gt;
                                &lt;div class=&quot;fieldName&quot;&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl00_FieldName&quot;&gt;Title&lt;/span&gt;
                                &lt;/div&gt;
                                &lt;div class=&quot;fieldData&quot;&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_title&quot;&gt;Aspirin use: percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field1'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_FieldName&quot;&gt;Source(s)&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 1, narrative. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_rptValues_ctl01_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 2, technical specifications. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptField_ctl01_rptValues_ctl02_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 3, specifications for survey measures. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
                &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_lblBookmarks&quot;&gt;
                    &lt;div style=&quot;clear:left;position:relative;&quot;&gt;
                        &lt;div class=&quot;content_bookmarks_box&quot;&gt;
                            &lt;img name=&quot;tabs_summary_imagemap&quot; id=&quot;tabs_summary_imagemap&quot; src=&quot;images/NQMC/tabs_summary_jump.gif&quot; border=&quot;0&quot; usemap=&quot;#m_tabs_summary_imagemap&quot; alt=&quot;&quot; /&gt;&lt;map name=&quot;m_tabs_summary_imagemap&quot; id=&quot;m_tabs_summary_imagemap&quot;&gt;&lt;area shape=&quot;poly&quot; coords=&quot;13,0,85,0,85,27,13,27,13,0&quot; href=&quot;javascript:;&quot; onmousedown=&quot;showDiv('jump');&quot; alt=&quot;Jump To&quot; /&gt;&lt;area shape=&quot;poly&quot; coords=&quot;92,0,241,0,241,27,92,27,92,0&quot; href=&quot;javascript:;&quot; onmousedown=&quot;showDiv('classification');&quot; alt=&quot;Guideline Classification&quot; /&gt;&lt;area shape=&quot;poly&quot; coords=&quot;247,0,364,0,364,27,247,27,247,0&quot; href=&quot;javascript:;&quot; onmousedown=&quot;showDiv('related');&quot; alt=&quot;Related Content&quot; /&gt;&lt;/map&gt;
                        &lt;/div&gt;
                        &lt;div class=&quot;content_bookmarks_box_top_line&quot;&gt;&lt;/div&gt;
                        &lt;div id=&quot;divJump&quot; class=&quot;content_jumplinks_box&quot;&gt;
                            &lt;table&gt;
                            &lt;tr&gt;
                            &lt;td valign=&quot;top&quot;&gt;
                                    &lt;div class=&quot;bookmark_left_dash&quot;&gt;
                                    &lt;/div&gt;
                                    &lt;div class=&quot;bookmark_right_text&quot;&gt;
                                        &lt;a href=&quot;#Section563&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks1_ctl00_aBookmark1&quot; class=&quot;content_jumplink&quot;&gt;Measure Domain&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section566&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks1_ctl01_aBookmark1&quot; class=&quot;content_jumplink&quot;&gt;Brief Abstract&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section573&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks1_ctl02_aBookmark1&quot; class=&quot;content_jumplink&quot;&gt;Evidence Supporting the Measure&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section580&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks1_ctl03_aBookmark1&quot; class=&quot;content_jumplink&quot;&gt;State of Use of the Measure&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section583&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks1_ctl04_aBookmark1&quot; class=&quot;content_jumplink&quot;&gt;Application of the Measure in its Current Use&lt;/a&gt;
                                    &lt;/div&gt;
                            &lt;/td&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section590&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks2_ctl00_aBookmark2&quot; class=&quot;content_jumplink&quot;&gt;Institute of Medicine (IOM) National Health Care Quality Report Categories&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section593&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks2_ctl01_aBookmark2&quot; class=&quot;content_jumplink&quot;&gt;Data Collection for the Measure&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section605&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks2_ctl02_aBookmark2&quot; class=&quot;content_jumplink&quot;&gt;Computation of the Measure&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section615&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks2_ctl03_aBookmark2&quot; class=&quot;content_jumplink&quot;&gt;Identifying Information&lt;/a&gt;
                                    &lt;/div&gt;
                                    &lt;/div&gt;
                                        &lt;a href=&quot;#Section99999&quot; id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_dlBookmarks2_ctl04_aBookmark2&quot; class=&quot;content_jumplink&quot;&gt;Disclaimer&lt;/a&gt;
                                    &lt;/div&gt;
                            &lt;/td&gt;
                            &lt;/tr&gt;
                            &lt;/table&gt;
                        &lt;/div&gt;
                        &lt;div id=&quot;div classification&quot; style=&quot;display:none;&quot; class=&quot;content_classification_tab_box&quot;&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_divDev&quot;&gt;
                                Developer: &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_lblDevs&quot;&gt;&lt;a href=&quot;/browse/by-organization.aspx?orgid=8&quot;&gt;National Committee for Quality Assurance&lt;/a&gt;&lt;/span&gt;&lt;br /&gt;
                            &lt;/div&gt;&lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_divAge&quot;&gt;
                                &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_lblAgeNQMC&quot;&gt;Target Population Age:&lt;/span&gt;
                                &lt;a href='/search/results.aspx?94=101'&gt;Adult: 65-79 years old&lt;/a&gt;; &lt;a href='/search/results.aspx?94=100'&gt;Adult: 45-64 years old&lt;/a&gt;&lt;br /&gt;
                            &lt;/div&gt;
                            &lt;div class=&quot;content_umls_tab_box&quot;&gt;
                                &lt;b&gt;UMLS Concepts&lt;/b&gt; (&lt;a href=&quot;#&quot; onclick=&quot;javascript:window.open('/about/faqPopup.aspx', 'Help','width=500,height=400,location=no');&quot;&gt;what's this?&lt;/a&gt;)&lt;br /&gt;
                                &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_lblClickToView&quot;&gt;Click to view all measure(s) indexed with these concepts&lt;/span&gt;&lt;br/&gt;
                                &lt;div style=&quot;padding:10px;&quot; id=&quot;divUMLSSummary&quot;&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSSummary_ctl00_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;ICD9CM&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Cardiovascular+disease%2c+unspecified&amp;vocab=ICD9CM&amp;code= (429.2)&amp;umls=1'&gt;Cardiovascular disease, unspecified&lt;/a&gt; (429.2)
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSSummary_ctl02_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MSH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin&amp;vocab=MSH&amp;code=&amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases&amp;vocab=MSH&amp;code=&amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention&amp;vocab=MSH&amp;code=&amp;umls=1'&gt;Chemoprevention&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSSummary_ctl04_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MTH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin&amp;vocab=MTH&amp;code=&amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases&amp;vocab=MTH&amp;code=&amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention&amp;vocab=MTH&amp;code=&amp;umls=1'&gt;Chemoprevention&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSSummary_ctl06_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;PDQ&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=acetylsalicyclic+acid&amp;vocab=PDQ&amp;code=&amp;umls=1'&gt;acetylsalicyclic acid&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSSummary_ctl08_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;SNOMEDCT&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin&amp;vocab=SNOMEDCT&amp;code= (387458008)&amp;umls=1'&gt;Aspirin&lt;/a&gt; (387458008); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system&amp;vocab=SNOMEDCT&amp;code= (105980002)&amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (105980002); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system&amp;vocab=SNOMEDCT&amp;code= (49601007)&amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (49601007)
                                &lt;/div&gt;
                                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_divShowAll&quot;&gt;
                                    &lt;a id=&quot;aShowAll&quot; onclick=&quot;showUMLSSection();&quot; style=&quot;cursor:pointer; cursor:hand;&quot;&gt;&lt;b&gt;Show all...&lt;/b&gt;&lt;/a&gt;
                                &lt;/div&gt;
                                &lt;div style=&quot;padding:10px;display:none;&quot; id=&quot;divUMLSAll&quot;&gt;
                                        &lt;br /&gt;
                                        &lt;br /&gt;
                                        &lt;br /&gt;
                                        &lt;br /&gt;
                                &lt;/div&gt;
                                &lt;a id=&quot;aHide&quot; onclick=&quot;hideUMLSSection();&quot; style=&quot;cursor:pointer; cursor:hand; display:none;&quot;&gt;&lt;b&gt;Hide...&lt;/b&gt;&lt;/a&gt;
                            &lt;/div&gt;
                        &lt;/div&gt;
                        &lt;div id=&quot;divRelated&quot; class=&quot;content_classification_tab_box&quot; style=&quot;display:none;&quot;&gt;
                            &lt;div class=&quot;content_related_inner_box&quot;&gt;
                                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_pnlHierarchy&quot;&gt;
                                    View all measures that are part of this hierarchy (&lt;a href=&quot;#&quot; onclick=&quot;javascript:window.open('/about/hierarchyPopup.aspx', 'Help','width=500,height=500,location=no');&quot;&gt;what's this?&lt;/a&gt;):&lt;br/&gt;
                                            &lt;div style=&quot;margin-left:10px;&quot;&gt;
                                                &lt;img src=&quot;images/NQMC/icon_hierarchy.gif&quot;  alt=&quot;Hierarchy icon&quot; style=&quot;margin-right:3px;&quot; /&gt;
                                                Collection: &lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=25908&quot;&gt;HEDIS&amp;reg; 2011: Healthcare Effectiveness Data &amp;amp; Information Set&lt;/a&gt;
                                            &lt;/div&gt;
                                            &lt;div style=&quot;margin-left:20px;&quot;&gt;
                                                Set: &lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=26143&quot;&gt;Effectiveness of Care&lt;/a&gt;
                                            &lt;/div&gt;
                                            &lt;div style=&quot;margin-left:30px;&quot;&gt;
                                                Subset: &lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=26331&quot;&gt;Measures Collected Through CAHPS Health Plan Survey&lt;/a&gt;
                                            &lt;/div&gt;
                                    &lt;div class=&quot;content_tab_hr&quot;&gt;&lt;img src=&quot;images/spacer.gif&quot; style=&quot;height:1px;&quot; alt=&quot;&quot; /&gt;&lt;/div&gt;
		&lt;/div&gt;&lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_pnlViewAll&quot;&gt;
                                    View all measure summaries by the developer(s): &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_lblViewAll&quot;&gt;&lt;a href=&quot;/browse/by-organization.aspx?orgid=8&quot;&gt;National Committee for Quality Assurance&lt;/a&gt;&lt;/span&gt;&lt;br/&gt;
		&lt;/div&gt;
                            &lt;/div&gt;
                        &lt;/div&gt;
                    &lt;/div&gt;
                &lt;/span&gt;
            &lt;/td&gt;
	&lt;/tr&gt;&lt;tr&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section563'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionBackToTop&quot;&gt;&lt;a href=&quot;#top&quot;&gt;Back to top&lt;/a&gt;&lt;/div&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_SectionName&quot;&gt;Measure Domain&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3025'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl00_FieldName&quot;&gt;Primary Measure Domain&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;Clinical Quality Measures: Process&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3026'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl01_FieldName&quot;&gt;Secondary Measure Domain&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl01_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Does not apply to this measure&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section566'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_SectionName&quot;&gt;Brief Abstract&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field34'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl00_FieldName&quot;&gt;Description&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;This measure uses survey data to assess the percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field21'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl01_FieldName&quot;&gt;Rationale&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;The United States Preventive Services Task Force (USPSTF) strongly recommends that clinicians discuss aspirin chemoprevention with adults who are at increased risk (five-year risk greater than or equal to 3 percent) for coronary heart disease (CHD). Discussions with patients should address both the potential benefits and harms of aspirin therapy. The American Diabetes Association (ADA) encourages the use of aspirin therapy (75-162 mg/day) as a primary prevention strategy in patients with type 1 or type 2 diabetes who are at increased cardiovascular risk, including those who are 40 years of age and older or who have additional risk factors (e.g., family history of cardiovascular disease [CVD], hypertension, smoking, dyslipidemia, albuminuria).&lt;/p&gt;
&lt;p&gt;In 2004, CHD was an underlying or contributing cause of death for 451,300 people and accounted for 1 of every 5 deaths in the United States. The prevalence of CHD for both sexes in 2005 was nearly 16 million people, or 7.3 percent of the American population. The cost of cardiovascular diseases and stroke in the United States for 2008 was estimated at $448.5 billion, including health expenditures and lost productivity resulting from morbidity and mortality (indirect costs). Evidence shows that age is a strong demographic factor for CHD. It is projected that by 2030, 1 in 5 Americans will be 65 or older. The need for CHD management is essential.&lt;/p&gt;
&lt;p&gt;Aspirin treatment has been shown to prevent one cardiovascular event over an average follow-up of 6.4 years. This means that, on average in a 6.4 year time period, the use of aspirin therapy results in a benefit of three cardiovascular events prevented per 1,000 women and four events prevented per 1,000 men. Aspirin has been shown to reduce CHD in patients with peripheral arterial disease, as well.&lt;/p&gt;
&lt;p&gt;Aspirin therapy (75-162 mg/day) as a secondary prevention strategy in patients who have diabetes and a history of CVD is also recommended.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field3500'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_FieldName&quot;&gt;Evidence for Rationale&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;American Heart Association. Heart disease and stroke statistics - 2008 update. Dallas (TX): American Heart Association; 2008. 43 p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_rptValues_ctl01_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;Berger JS, Roncaglioni MC, Avanzini F, Pangrazzi I, Tognoni G, Brown DL. Aspirin for the primary prevention of cardiovascular events in women and men: a sex-specific meta-analysis of randomized controlled trials. JAMA&amp;nbsp;2006 Jan 18;295(3):306-13. &lt;a href=&quot;http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&amp;db=pubmed&amp;dopt=Abstract&amp;list_uids=16418466&quot; target=&quot;_blank&quot;&gt;PubMed&lt;/a&gt; &lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_rptValues_ctl02_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;Berra K, Miller NH, Fair JM. Cardiovascular disease prevention and disease management: A critical role for nursing. J Cardiopulm Rehabil&amp;nbsp;2006 Jul-Aug;26(4):197-206. [39 references] &lt;a href=&quot;http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&amp;db=pubmed&amp;dopt=Abstract&amp;list_uids=16926682&quot; target=&quot;_blank&quot;&gt;PubMed&lt;/a&gt; &lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_rptValues_ctl03_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;Kikano GE, Brown MT. Antiplatelet therapy for atherothrombotic disease: an update for the primary care physician. Mayo Clin Proc&amp;nbsp;2007 May;82(5):583-93. [67 references] &lt;a href=&quot;http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&amp;db=pubmed&amp;dopt=Abstract&amp;list_uids=17511957&quot; target=&quot;_blank&quot;&gt;PubMed&lt;/a&gt; &lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl02_rptValues_ctl04_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 1, narrative. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl03_divOuter&quot;&gt;
                                &lt;a id='Field3022'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl03_FieldName&quot;&gt;Primary Health Components&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl03_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl03_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Aspirin use; cardiovascular disease (CVD)&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl04_divOuter&quot;&gt;
                                &lt;a id='Field23'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl04_FieldName&quot;&gt;Denominator Description&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl04_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl04_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;The number of eligible members who are women 56 through 79 and men 46 through 79 years of age and who responded to the survey (see the related &quot;Denominator Inclusions/Exclusions&quot; field)&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl05_divOuter&quot;&gt;
                                &lt;a id='Field24'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl05_FieldName&quot;&gt;Numerator Description&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl05_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl02_rptField_ctl05_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;The number of members in the denominator who indicated that their doctor or other provider discussed the risks and benefits of aspirin use to prevent heart attack or stroke&lt;/p&gt;
&lt;p class=&quot;Note&quot;&gt;&lt;strong&gt;Note&lt;/strong&gt;: Refer to the original measure documentation for information regarding survey questions.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section573'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_SectionName&quot;&gt;Evidence Supporting the Measure&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3027'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl00_FieldName&quot;&gt;Type of Evidence Supporting the Criterion of Quality for the Measure&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;ul&gt;&lt;li&gt;A clinical practice guideline or other peer-reviewed synthesis of the clinical research evidence&lt;/li&gt;&lt;li&gt;A formal consensus procedure, involving experts in relevant clinical, methodological,  public health and organizational sciences&lt;/li&gt;&lt;li&gt;One or more research studies published in a National Library of Medicine (NLM) indexed, peer-reviewed journal&lt;/li&gt;&lt;/ul&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3501'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl01_FieldName&quot;&gt;Other Characteristics Concerning the Measure&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Unspecified&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field3072'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl02_FieldName&quot;&gt;Extent of Measure Testing&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl03_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Unspecified&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section580'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_SectionName&quot;&gt;State of Use of the Measure&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3029'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl00_FieldName&quot;&gt;State of Use&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;Current routine use&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3030'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_FieldName&quot;&gt;Current Use&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Accreditation &lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl01_Value&quot;&gt;Decision-making by businesses about health plan purchasing&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl02_Value&quot;&gt;Decision-making by consumers about health plan/provider choice&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl03_Value&quot;&gt;External oversight/Medicaid&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl04_Value&quot;&gt;External oversight/State government program&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl04_rptField_ctl01_rptValues_ctl05_Value&quot;&gt;Internal quality improvement&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section583'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_SectionName&quot;&gt;Application of the Measure in its Current Use&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3031'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl00_FieldName&quot;&gt;Measurement Setting&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;Managed Care Plans&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3032'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl01_FieldName&quot;&gt;Professionals Involved in Delivery of Health Services&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Does not apply to this measure (e.g., measure is not provider specific)&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field3033'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl02_FieldName&quot;&gt;Least Aggregated Level of Services Delivery Addressed&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;Single Health Care Delivery or Public Health Organizations&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl03_divOuter&quot;&gt;
                                &lt;a id='Field3505'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl03_FieldName&quot;&gt;Statement of Acceptable Minimum Sample Size&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl03_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl03_rptValues_ctl00_Value&quot;&gt;Specified&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl04_divOuter&quot;&gt;
                                &lt;a id='Field41'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl04_FieldName&quot;&gt;Target Population Age&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl04_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl04_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Men 46 through 79 years of age; women 56 through 79 years of age&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl05_divOuter&quot;&gt;
                                &lt;a id='Field42'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl05_FieldName&quot;&gt;Target Population Gender&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl05_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl05_rptField_ctl05_rptValues_ctl00_Value&quot;&gt;Either male or female&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section590'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_SectionName&quot;&gt;Institute of Medicine (IOM) National Health Care Quality Report Categories&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3163'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl00_FieldName&quot;&gt;IOM Care Need&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;Staying Healthy&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3164'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl01_FieldName&quot;&gt;IOM Domain&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Effectiveness&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl06_rptField_ctl01_rptValues_ctl01_Value&quot;&gt;Patient-centeredness&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section593'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_SectionName&quot;&gt;Data Collection for the Measure&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3506'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl00_FieldName&quot;&gt;Case Finding Period&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;The measurement year&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3054'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl01_FieldName&quot;&gt;Denominator Sampling Frame&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Enrollees or beneficiaries&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field55'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl02_FieldName&quot;&gt;Denominator Inclusions/Exclusions&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;&lt;strong&gt;Inclusions&lt;/strong&gt;&lt;br /&gt;
The number of eligible* members who are women 56 through 79 and men 46 through 79 years of age and who responded to the survey&lt;/p&gt;
&lt;p class=&quot;Note&quot;&gt;*&lt;em&gt;Eligible Population&lt;/em&gt;: Men ages 46 through 79 and women ages 56 through 79 as of December 31 of the measurement year who were continuously enrolled during the measurement year (commercial) or for the last six months of the measurement year (Medicaid), and currently enrolled at the time the survey is completed.&lt;/p&gt;
&lt;p class=&quot;Note&quot;&gt;&lt;em&gt;Allowable Gap&lt;/em&gt;: No more than one gap in enrollment of up to 45 days during the measurement year (commercial). To determine continuous enrollment for a Medicaid beneficiary for whom enrollment is verified monthly, the member may not have more than a 1-month gap in coverage.&lt;/p&gt;
&lt;p class=&quot;Note&quot;&gt;&lt;strong&gt;Note&lt;/strong&gt;: Refer to original measure documentation for additional information regarding eligibility and survey questions.&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Exclusions&lt;/strong&gt;&lt;br /&gt;
Any response to the following question indicates a cardiovascular disease (CVD) exclusion:&lt;/p&gt;
&lt;ul style=&quot;list-style-type: disc;&quot;&gt;
    &lt;li&gt;&quot;Has a doctor ever told you that you have any of the following conditions? Check all that apply.&quot; &lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;Exclude any member who selected &lt;em&gt;any&lt;/em&gt; response choice: &quot;A heart attack&quot; or &quot;Angina or coronary heart disease&quot; or &quot;A stroke&quot; or &quot;Any kind of diabetes or high blood sugar.&quot;&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl03_divOuter&quot;&gt;
                                &lt;a id='Field3507'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl03_FieldName&quot;&gt;Exclusions/Exceptions&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl03_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl03_rptValues_ctl00_Value&quot;&gt;Unspecified&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl04_divOuter&quot;&gt;
                                &lt;a id='Field3057'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl04_FieldName&quot;&gt;Denominator (Index) Event or Characteristic&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl04_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl04_rptValues_ctl00_Value&quot;&gt;Patient/Individual (Consumer) Characteristic&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl05_divOuter&quot;&gt;
                                &lt;a id='Field3058'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl05_FieldName&quot;&gt;Denominator Time Window&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl05_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl05_rptValues_ctl00_Value&quot;&gt;Time window brackets index event&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl06_divOuter&quot;&gt;
                                &lt;a id='Field59'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl06_FieldName&quot;&gt;Numerator Inclusions/Exclusions&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl06_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl06_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;&lt;strong&gt;Inclusions&lt;/strong&gt;&lt;br /&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl07_divOuter&quot;&gt;
                                &lt;a id='Field3061'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl07_FieldName&quot;&gt;Numerator Search Strategy&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl07_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl07_rptValues_ctl00_Value&quot;&gt;Fixed time period&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl08_divOuter&quot;&gt;
                                &lt;a id='Field3062'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl08_FieldName&quot;&gt;Data Source&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl08_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl08_rptValues_ctl00_Value&quot;&gt;Administrative clinical data&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl08_rptValues_ctl01_Value&quot;&gt;Patient/Individual survey&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl09_divOuter&quot;&gt;
                                &lt;a id='Field3066'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl09_FieldName&quot;&gt;Instruments Used and/or Associated with the Measure&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl09_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl07_rptField_ctl09_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;CAHPS&amp;reg; 4.0H Adult Survey&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section605'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_SectionName&quot;&gt;Computation of the Measure&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field3508'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl00_FieldName&quot;&gt;Measure Specifies Disaggregation&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;Does not apply to this measure&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field3067'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl01_FieldName&quot;&gt;Scoring&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;Rate/Proportion&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field3068'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl02_FieldName&quot;&gt;Interpretation of Score&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;Desired value is a higher score&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl03_divOuter&quot;&gt;
                                &lt;a id='Field3090'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl03_FieldName&quot;&gt;Allowance for Patient or Population Factors&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl03_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl03_rptValues_ctl00_Value&quot;&gt;Analysis by subgroup (stratification by individual factors, geographic factors, etc.)&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl04_divOuter&quot;&gt;
                                &lt;a id='Field3069'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl04_FieldName&quot;&gt;Description of Allowance for Patient or Population Factors&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl04_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl04_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;This measure requires that separate rates be reported for commercial and Medicaid product lines.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_divOuter&quot;&gt;
                                &lt;a id='Field3070'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_FieldName&quot;&gt;Standard of Comparison&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_rptValues_ctl00_Value&quot;&gt;External comparison at a point in, or interval of, time&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_rptValues_ctl01_Value&quot;&gt;External comparison of time trends&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl08_rptField_ctl05_rptValues_ctl02_Value&quot;&gt;Internal time comparison&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section615'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_SectionName&quot;&gt;Identifying Information&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field73'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl00_FieldName&quot;&gt;Original Title&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Aspirin use and discussion (ASP).&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl01_divOuter&quot;&gt;
                                &lt;a id='Field74'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl01_FieldName&quot;&gt;Measure Collection Name&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl01_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl01_rptValues_ctl00_Value&quot;&gt;&lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=25908&quot;&gt;HEDIS&amp;reg; 2011: Healthcare Effectiveness Data &amp;amp; Information Set&lt;/a&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl02_divOuter&quot;&gt;
                                &lt;a id='Field75'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl02_FieldName&quot;&gt;Measure Set Name&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl02_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl02_rptValues_ctl00_Value&quot;&gt;&lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=26143&quot;&gt;Effectiveness of Care&lt;/a&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl03_divOuter&quot;&gt;
                                &lt;a id='Field77'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl03_FieldName&quot;&gt;Measure Subset Name&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl03_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl03_rptValues_ctl00_Value&quot;&gt;&lt;a href=&quot;/browse/by-organization-indiv.aspx?objid=26331&quot;&gt;Measures Collected Through CAHPS Health Plan Survey&lt;/a&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl04_divOuter&quot;&gt;
                                &lt;a id='Field16'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl04_FieldName&quot;&gt;Submitter&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl04_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl04_rptValues_ctl00_Value&quot;&gt;National Committee for Quality Assurance - Health Care Accreditation Organization&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl05_divOuter&quot;&gt;
                                &lt;a id='Field17'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl05_FieldName&quot;&gt;Developer&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl05_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl05_rptValues_ctl00_Value&quot;&gt;National Committee for Quality Assurance - Health Care Accreditation Organization&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl06_divOuter&quot;&gt;
                                &lt;a id='Field79'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl06_FieldName&quot;&gt;Funding Source(s)&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl06_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl06_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Unspecified&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl07_divOuter&quot;&gt;
                                &lt;a id='Field80'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl07_FieldName&quot;&gt;Composition of the Group that Developed the Measure&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl07_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl07_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;National Committee for Quality Assurance's (NCQA's) Measurement Advisory Panels (MAPs) are composed of clinical and research experts with an understanding of quality performance measurement in the particular clinical content areas.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl08_divOuter&quot;&gt;
                                &lt;a id='Field81'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl08_FieldName&quot;&gt;Financial Disclosures/Other Potential Conflicts of Interest&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl08_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl08_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;In order to fulfill National Committee for Quality Assurance's (NCQA's) mission and vision of improving health care quality through measurement, transparency and accountability, all participants in NCQA's expert panels are required to disclose potential conflicts of interest prior to their participation. The goal of this Conflict Policy is to ensure that decisions which impact development of NCQA's products and services are made as objectively as possible, without improper bias or influence.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl09_divOuter&quot;&gt;
                                &lt;a id='Field19'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl09_FieldName&quot;&gt;Adaptation&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl09_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl09_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;For commercial and Medicaid members, this measure is collected using the HEDIS (Healthcare Effectiveness Data and Information Set) version of the CAHPS&amp;reg; survey (CAHPS&amp;reg; 4.0H Adult Survey).&lt;/p&gt;
&lt;p&gt;CAHPS&amp;reg; 4.0 is sponsored by the Agency for Healthcare Research and Quality (AHRQ).&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl10_divOuter&quot;&gt;
                                &lt;a id='Field3086'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl10_FieldName&quot;&gt;Date of Most Current Version in NQMC&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl10_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl10_rptValues_ctl00_Value&quot;&gt;2010 Jul&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl11_divOuter&quot;&gt;
                                &lt;a id='Field3511'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl11_FieldName&quot;&gt;Measure Maintenance&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl11_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl11_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Unspecified&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl12_divOuter&quot;&gt;
                                &lt;a id='Field3512'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl12_FieldName&quot;&gt;Date of Next Anticipated Revision&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl12_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl12_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;Unspecified&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl13_divOuter&quot;&gt;
                                &lt;a id='Field20'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl13_FieldName&quot;&gt;Measure Status&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl13_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl13_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;This is the current release of the measure.&lt;/p&gt;
&lt;p&gt;This measure updates a previous version: National Committee for Quality Assurance (NCQA). HEDIS&amp;reg; 2010: Healthcare Effectiveness Data &amp;amp; Information Set. Vol. 2, Technical Specifications. Washington (DC): National Committee for Quality Assurance (NCQA); 2009 Jul. 417 p.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_divOuter&quot;&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_FieldName&quot;&gt;Source(s)&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_rptValues_ctl00_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 1, narrative. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_rptValues_ctl01_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 2, technical specifications. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;br /&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl14_rptValues_ctl02_Value&quot;&gt;&lt;table&gt;&lt;tr&gt;&lt;td&gt;National Committee for Quality Assurance (NCQA). HEDIS® 2011: Healthcare Effectiveness Data and Information Set. Vol. 3, specifications for survey measures. Washington (DC): National Committee for Quality Assurance (NCQA); 2010. various p. &lt;/td&gt;&lt;/tr&gt;&lt;/table&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl15_divOuter&quot;&gt;
                                &lt;a id='Field14'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl15_FieldName&quot;&gt;Measure Availability&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl15_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl15_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;The individual measure, &quot;Aspirin Use and Discussion (ASP),&quot; is published in &quot;HEDIS&amp;reg; 2011. Healthcare Effectiveness Data &amp;amp; Information Set. Vol. 2, Technical Specifications.&quot; &lt;/p&gt;
&lt;p&gt;For more information, contact the National Committee for Quality Assurance (NCQA) at 1100 13th Street, NW, Suite 1000, Washington, DC 20005; Telephone: 202-955-3500; Fax: 202-955-3599; Web site: &lt;a href=&quot;disclaimer.aspx?redirect=http://www.ncqa.org/&quot; title=&quot;NCQA Web site&quot;&gt;www.ncqa.org&lt;/a&gt;&amp;nbsp;&lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl16_divOuter&quot;&gt;
                                &lt;a id='Field87'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl16_FieldName&quot;&gt;NQMC Status&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl16_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl16_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;This NQMC summary was completed by ECRI Institute on April 30, 2010. This NQMC summary was updated by ECRI Institute on May 2, 2011. This NQMC summary was updated again by ECRI Institute on May 25, 2011.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl17_divOuter&quot;&gt;
                                &lt;a id='Field88'&gt;&lt;/a&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl17_FieldName&quot;&gt;Copyright Statement&lt;/span&gt;
                                &lt;/div&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl17_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl09_rptField_ctl17_rptValues_ctl00_Value&quot;&gt;&lt;div class=&quot;content_para&quot;&gt;&lt;p&gt;This NQMC summary is based on the original measure, which is subject to the measure developer's copyright restrictions.&lt;/p&gt;
&lt;p&gt;For detailed specifications regarding the National Committee on Quality Assurance (NCQA) measures, refer to HEDIS Volume 2: Technical Specifications, available from the NCQA Web site at &lt;a href=&quot;disclaimer.aspx?redirect=http://www.ncqa.org/&quot; title=&quot;NCQA Web site&quot;&gt;www.ncqa.org&lt;/a&gt;&amp;nbsp;&lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;.&lt;/p&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
		&lt;td&gt;
                &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_divSectionName&quot; class=&quot;SectionLbl&quot;&gt;
                    &lt;a id='Section99999'&gt;&lt;/a&gt;
                    &lt;div class=&quot;SectionTitle&quot;&gt;&lt;h2&gt;&lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_SectionName&quot;&gt;Disclaimer&lt;/span&gt;&lt;/h2&gt;&lt;/div&gt;
                &lt;/div&gt;
                &lt;div&gt;
                            &lt;div id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_rptField_ctl00_divOuter&quot;&gt;
                                &lt;a id='Field99999'&gt;&lt;/a&gt;
                                &lt;div class=&quot;fieldName&quot;&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_rptField_ctl00_FieldName&quot;&gt;NQMC Disclaimer&lt;/span&gt;
                                &lt;/div&gt;
                                &lt;div class=&quot;fieldData&quot;&gt;
                                    &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_rptField_ctl00_nofieldtext&quot;&gt;&lt;/span&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl10_rptField_ctl00_rptValues_ctl00_Value&quot;&gt;&lt;div id=&quot;divDisclaimerShort&quot;&gt;&lt;p&gt;The National Quality Measures Clearinghouse™ (NQMC) does not develop, produce, approve, or endorse the measures represented on this site.&lt;/p&gt;&lt;a id=&quot;aShowDisc&quot; class=&quot;javascriptLink&quot; onclick=&quot;showDisclaimer();&quot;&gt;&lt;b&gt;Read full disclaimer...&lt;/b&gt;&lt;/a&gt;&lt;/div&gt;&lt;div style=&quot;display:none;&quot; id=&quot;divDisclaimerAll&quot;&gt;&lt;p&gt;The National Quality Measures Clearinghouse™ (NQMC) does not develop, produce, approve, or endorse the measures represented on this site.&lt;/p&gt; &lt;p&gt;All measures summarized by NQMC and hosted on our site are produced under the auspices of medical specialty societies, relevant professional associations, public and private organizations, other government agencies, health care organizations or plans, individuals, and similar entities.&lt;/p&gt; &lt;p&gt;Measures represented on the NQMC Web site are submitted by measure developers, and are screened solely to determine that they meet the NQMC Inclusion Criteria which may be found at &lt;a href=&quot;../about/inclusion-criteria.aspx&quot;&gt;http://www.qualitymeasures.ahrq.gov/about/inclusion-criteria.aspx&lt;/a&gt;&amp;nbsp;&lt;img alt=&quot;External Web Site Policy&quot; src=&quot;/images/icon_externallink.gif&quot; /&gt;.&lt;/p&gt; &lt;p&gt;NQMC, AHRQ, and its contractor ECRI Institute make no warranties concerning the content or its reliability and/or validity of the quality measures and related materials represented on this site. Moreover, the views and opinions of developers or authors of measures represented on this site do not necessarily state or reflect those of NQMC, AHRQ, or its contractor, ECRI Institute, and inclusion or hosting of measures in NQMC may not be used for advertising or commercial endorsement purposes.&lt;/p&gt; &lt;p&gt;Readers with questions regarding measure content are directed to contact the measure developer.&lt;/p&gt;&lt;a id=&quot;aHideDisc&quot; onclick=&quot;hideDisclaimer();&quot; class=&quot;javascriptLink&quot;&gt;&lt;b&gt;Hide...&lt;/b&gt;&lt;/a&gt;&lt;/div&gt;&lt;/span&gt;
                                &lt;/div&gt;
                            &lt;/div&gt;
                &lt;/div&gt;
            &lt;/td&gt;
	&lt;/tr&gt;
&lt;/table&gt;
    &lt;/div&gt;
    &lt;div id=&quot;ctl00_ContentPlaceHolder1_pnlDownload&quot;&gt;
&lt;/div&gt;
    &lt;div id=&quot;ctl00_ContentPlaceHolder1_RadWindowManager&quot; style=&quot;display:none;&quot;&gt;
	&lt;div id=&quot;ctl00_ContentPlaceHolder1_Help&quot; style=&quot;display:none;&quot;&gt;
		&lt;div id=&quot;ctl00_ContentPlaceHolder1_Help_C&quot;&gt;
		&lt;/div&gt;&lt;input id=&quot;ctl00_ContentPlaceHolder1_Help_ClientState&quot; name=&quot;ctl00_ContentPlaceHolder1_Help_ClientState&quot; type=&quot;hidden&quot; /&gt;
	&lt;/div&gt;&lt;div id=&quot;ctl00_ContentPlaceHolder1_RadWindowManager_alerttemplate&quot; style=&quot;display:none;&quot;&gt;
		&lt;div class=&quot;rwDialogPopup radalert&quot;&gt;
			&lt;div class=&quot;rwDialogText&quot;&gt;
			{1}
			&lt;/div&gt;
			&lt;div&gt;
				&lt;a  onclick=&quot;$find('{0}').close();&quot;
				class=&quot;rwPopupButton&quot; href=&quot;javascript:void(0);&quot;&gt;
					&lt;span class=&quot;rwOuterSpan&quot;&gt;
						&lt;span class=&quot;rwInnerSpan&quot;&gt;##LOC[OK]##&lt;/span&gt;
					&lt;/span&gt;
				&lt;/a&gt;
			&lt;/div&gt;
		&lt;/div&gt;
		&lt;/div&gt;&lt;div id=&quot;ctl00_ContentPlaceHolder1_RadWindowManager_prompttemplate&quot; style=&quot;display:none;&quot;&gt;
		 &lt;div class=&quot;rwDialogPopup radprompt&quot;&gt;
			    {1}
			    &lt;/div&gt;
			    &lt;div&gt;
				    &lt;script type=&quot;text/javascript&quot;&gt;
				    function RadWindowprompt_detectenter(id, ev, input)
					    if (!ev) ev = window.event;
					    if (ev.keyCode == 13)
					        var but = input.parentNode.parentNode.getElementsByTagName(&quot;A&quot;)[0];
					        if (but)
							    if (but.click) but.click();
							    else if (but.onclick)
							        but.focus(); var click = but.onclick; but.onclick = null; if (click) click.call(but);
					       return false;
					    else return true;
				    &lt;/script&gt;
				    &lt;input  onkeydown=&quot;return RadWindowprompt_detectenter('{0}', event, this);&quot; type=&quot;text&quot;  class=&quot;rwDialogInput&quot; value=&quot;{2}&quot; /&gt;
			    &lt;/div&gt;
			    &lt;div&gt;
				    &lt;a onclick=&quot;$find('{0}').close(this.parentNode.parentNode.getElementsByTagName('input')[0].value);&quot;
					    class=&quot;rwPopupButton&quot; href=&quot;javascript:void(0);&quot; &gt;&lt;span class=&quot;rwOuterSpan&quot;&gt;&lt;span class=&quot;rwInnerSpan&quot;&gt;##LOC[OK]##&lt;/span&gt;&lt;/span&gt;&lt;/a&gt;
				    &lt;a onclick=&quot;$find('{0}').close(null);&quot; class=&quot;rwPopupButton&quot;  href=&quot;javascript:void(0);&quot;&gt;&lt;span class=&quot;rwOuterSpan&quot;&gt;&lt;span class=&quot;rwInnerSpan&quot;&gt;##LOC[Cancel]##&lt;/span&gt;&lt;/span&gt;&lt;/a&gt;
			    &lt;/div&gt;
		    &lt;/div&gt;
		&lt;/div&gt;&lt;div id=&quot;ctl00_ContentPlaceHolder1_RadWindowManager_confirmtemplate&quot; style=&quot;display:none;&quot;&gt;
		&lt;div class=&quot;rwDialogPopup radconfirm&quot;&gt;
			{1}
			&lt;/div&gt;
			&lt;div&gt;
				&lt;a onclick=&quot;$find('{0}').close(true);&quot;  class=&quot;rwPopupButton&quot; href=&quot;javascript:void(0);&quot; &gt;&lt;span class=&quot;rwOuterSpan&quot;&gt;&lt;span class=&quot;rwInnerSpan&quot;&gt;##LOC[OK]##&lt;/span&gt;&lt;/span&gt;&lt;/a&gt;
				&lt;a onclick=&quot;$find('{0}').close(false);&quot; class=&quot;rwPopupButton&quot;  href=&quot;javascript:void(0);&quot;&gt;&lt;span class=&quot;rwOuterSpan&quot;&gt;&lt;span class=&quot;rwInnerSpan&quot;&gt;##LOC[Cancel]##&lt;/span&gt;&lt;/span&gt;&lt;/a&gt;
			&lt;/div&gt;
		&lt;/div&gt;
		&lt;/div&gt;&lt;input id=&quot;ctl00_ContentPlaceHolder1_RadWindowManager_ClientState&quot; name=&quot;ctl00_ContentPlaceHolder1_RadWindowManager_ClientState&quot; type=&quot;hidden&quot; /&gt;
&lt;/div&gt;
                &lt;div style=&quot;clear:both;&quot;&gt;&lt;/div&gt;
            &lt;/div&gt;
        &lt;/div&gt;
    &lt;/div&gt;
    &lt;/body&gt;&lt;/html&gt;</value>
		</element>
		<element name="languages">
			<value>English</value>
		</element>
		<element name="mauthentication">
			<value>No log-in required</value>
		</element>
		<element name="mauthororganisations">
			<value>National Committee for Quality Assurance - Health Care Accreditation Organization</value>
		</element>
		<element name="mavailability">
			<value>General public</value>
		</element>
		<element name="mdbid">
			<value>http://www.qualitymeasures.ahrq.gov/content.aspx?id=32558</value>
		</element>
		<element name="mpublisher">
			<value>National Quality Measures Clearinghouse</value>
		</element>
		<element name="mrtype">
			<value>Measure</value>
		</element>
		<element name="msourcename">
			<value>Agency for Healthcare Research and Quality</value>
		</element>
		<element name="msubjectgen">
			<value>
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl00_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;ICD9CM&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Cardiovascular+disease%2c+unspecified &amp;umls=1'&gt;, unspecified&lt;/a&gt; (429.2)
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl02_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MSH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases &amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention &amp;umls=1'&gt;Chemoprevention&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Patient+Education+as+Topic &amp;umls=1'&gt;Patient Education as Topic&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl04_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;MTH&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Cardiovascular+Diseases &amp;umls=1'&gt;Cardiovascular Diseases&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Chemoprevention &amp;umls=1'&gt;Chemoprevention&lt;/a&gt;; &lt;a href='/search/search.aspx?term=Patient+education+(procedure) &amp;umls=1'&gt;Patient education (procedure)&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl06_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;PDQ&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=acetylsalicyclic+acid &amp;umls=1'&gt;acetylsalicyclic acid&lt;/a&gt;
                                        &lt;br /&gt;
                                            &lt;span id=&quot;ctl00_ContentPlaceHolder1_dlXML_ctl00_rptUMLSAll_ctl08_lblSab&quot; class=&quot;content_umls_sab&quot;&gt;SNOMEDCT&lt;/span&gt;:
                                            &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt; (387458008); &lt;a href='/search/search.aspx?term=Aspirin &amp;umls=1'&gt;Aspirin&lt;/a&gt; (7947003); &lt;a href='/search/search.aspx?term=Aspirin+prophylaxis &amp;umls=1'&gt;Aspirin prophylaxis&lt;/a&gt; (312452009); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system &amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (105980002); &lt;a href='/search/search.aspx?term=Disorder+of+cardiovascular+system &amp;umls=1'&gt;Disorder of cardiovascular system&lt;/a&gt; (49601007); &lt;a href='/search/search.aspx?term=Patient+education &amp;umls=1'&gt;Patient education&lt;/a&gt; (311401005); &lt;a href='/search/search.aspx?term=Prophylactic+chemotherapy &amp;umls=1'&gt;Prophylactic chemotherapy&lt;/a&gt; (268500004); &lt;a href='/search/search.aspx?term=Taking+aspirin+education &amp;umls=1'&gt;Taking aspirin education&lt;/a&gt; (315045009)
                                </value>
		</element>
		<element name="teaser">
			<value>&lt;p&gt;This measure uses survey data to assess the percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.&lt;/p&gt;</value>
		</element>
		<element name="title">
			<value>Aspirin use: percentage of women 56 through 79 years and men 46 through 79 years who discussed the risks and benefits of using aspirin with a doctor or other health provider.</value>
		</element>
		<element name="url">
		</element>
	</document>
</documents>
Geert BormansInformation ArchitectCommented:
well, again, if you could avoid text processing in XSLT1 in favour of structure processing, you should, since you will get more reliable code
... so I still think it is a good recomendation to dig deeper to get XHTML instead of a text node
Having said that, you could make your filter a bit smarter to drop the span elements and only keep the <a> elements,
then all you have is the anchor elements to deal with
since this is .net, you could make a two pass in msxsl using nodesets
just create some xml in a variable, cast it to a nodeset and have a second run through it
then you do have xml to deal with, so you could remove the duplicates easily
mmalik15Author Commented:
welcome
