Solved
I am having and issue with my iphone 4, there is no sound. I have checked to make sure it was not muted and that the volume was turned up but I still do not have sound. Has anyone else had this proble
Posted on 2011-09-21
Last Modified: 2012-05-12
I am having and issue with my iphone 4, there is no sound. I have checked to make sure it was not muted and that the volume was turned up but I still do not have sound. Has anyone else had this problem?
Question by:5g6tdcv4
3 Comments
LVL 4
Assisted Solution
by:jrobillard
jrobillard earned 1000 total points
Hi
Some people have already fix this problem by cleaning the earpiece with something.
The iphone think that have a earpiece and block the self speaker.
LVL 2
Accepted Solution
by:
Wild_Tech earned 1000 total points
I had an issue similar to this a while ago. Just get a q tip and stick it in the headphone jack to clean that part out. A lot of times stuff gets trapped in there and makes the iphone think it has some kind of headphones in ti. whatever you do, do not blow in the jack. you could set of the moisture sensor in the headphone jack.
LVL 13
Author Closing Comment
by:5g6tdcv4
Thanks Sound works again.
I selected the second comment as answer because it was written clearer and will help others.
Split the points 50/50
Free Tool: ZipGrep
Join & Write a Comment
If you have a smartphone, I'm sure you've noticed that web applications are changing. Yet, are you aware of how these changes are going to impact your organization or company?
Read this post to discover how will you get your first iPhone App Approved by Apple. Make these necessary changes to prevent rejection of the app.
When you create an app prototype with Adobe XD, you can insert system screens -- sharing or Control Center, for example -- with just a few clicks. This video shows you how. You can take the full course on Experts Exchange at http://bit.ly/XDcourse.
This video demonstrates how to sync Microsoft Exchange Public Folders with smartphones using CodeTwo Exchange Sync and Exchange ActiveSync. To learn more about CodeTwo Exchange Sync and download the free trial, go to: http://www.codetwo.com/excha…
595 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
