Solved
How to run sql block using shell script and exit if error occurs?
Posted on 2011-09-22
8
Last Modified: 2012-05-12
I am running a simple sql block using below shell script. There is a syntax error in sql block so whenever below shell script try to run sql block using sqlplus command, this script should fail and send a "failure_subject" email. But every time I run this test script I get "success_subject" email. Please advise what I am missing here.
# Oracle Environment Variables
. $HOME/.profile
ORA_USER=user
ORA_PWD=password
# Local Variables
run_date=`date '+%Y%m%d'`
run_time=`date '+%H%M%S'`
shell_dir=$HOME/analytics/bin
sql_dir=$HOME/analytics/sql
tmp_dir=$HOME/analytics/tmp
log_dir=$HOME/analytics/log
progName=${0##*/}
tmp_file1=${tmp_dir}/${progName%%.*}_${run_date}${run_time}.1.sql
log_file=${log_dir}/${progName%%.*}_${run_date}${run_time}.log
success_subject="Test script job success: $run_date"
failure_subject="Test script job failure: $run_date"
success_mailto="xcm0@txu.com"
failure_mailto="xcm0@txu.com"
start_time=`date +%Y-%m-%d-%H:%M:%S`
cat <<- EOF > $tmp_file1
set echo off;
set heading off;
set feedback off;
whenever sqlerror exit;
SELECT SYSDATE,         --Syntax error so script should fail and exit
from dual;
exit;
EOF
seg_snap_date=`sqlplus -s ${ORA_USER}/${ORA_PWD}@ADWPRD @$tmp_file1` >> ${log_file}
#Script should fail to execute above statement
if [[ $? -ne 0 ]]; then
    mailx -s"$failure_subject" "$failure_mailto" < $log_file > /dev/null
    cat $log_file
    exit 1
fi
#I should get an email from above if statement block
if [[ $? -eq 0 ]]; then
    mailx -s"$success_subject" "$success_mailto" < ${log_file}
fi
#But I am getting an email from above block
cat $log_file
exit $?
Question by:IT_ETL
  • 3
  • 2
  • 2
  • +1
8 Comments
LVL 78
Expert Comment
by:slightwv (䄆 Netminder)
It is already in there:  whenever sqlerror exit
Is it not working?
LVL 15
Expert Comment
by:Devinder Singh Virdi
Simple example:
run the following
select count(*) from asdfiasfj;   --- note this table is not present
you will get Ora 942 error table or view does not exists
---- Now run
--- your session will be disconnected.
LVL 15
Expert Comment
So you are good, because your script already has that, as explained by slightwv.
LVL 21
Accepted Solution
by:
flow01 earned 1600 total points
try
whenever sqlerror exit failure;
it should set a return code indicating failure
Author Comment
by:IT_ETL
I have modified the script little bit. I have deleted "whenever sqlerror exit" line and just ran the sql block using sqlplus command. The script ran and I got an email with "success_subject" but I really should have received an email that has "failure_subject". Please see below code and advise.
. $HOME/.profile
ORA_USER=user
ORA_PWD=password
# Local Variables
progName=${0##*/}
echo "$start_time" >> ${log_file}
set echo off;
set heading off;
set feedback off;
SELECT SYSDATE,
from dual;
exit;
EOF
    cat $log_file
    exit 1
fi
fi
cat $log_file
exit $?
LVL 78
Assisted Solution
slightwv (䄆 Netminder) earned 400 total points
Why?  This is the line that should cause the error code.  Did you add 'failure' like suggested above?
Also, my shell scripting is rusty but I think you have a logic issue:  if the ret. code sends the fail message, your next if check for. $? For success will likely be based off the mailx command.
LVL 15
Expert Comment
You can add the following as well to check for any Ora- errors:-
set echo off;
set heading off;
set feedback off;
SPOOL /home/work/log/File1.log  ----------------- New line
SELECT SYSDATE, from dual;
exit;
EOF
CNT=`grep -i ora- /home/work/log/File1.log |wc -l`   ------------ New Line
if [[ $CNT -ne 0 ]]; then  --------------------- New Line
    cat $log_file
    exit 1
fi
Since you have put comma after sysdate, log file will reflect Ora- error and you will get desire result.
Author Comment
by:IT_ETL
I have added below line as suggested in the above script and it is working now.
Thanks everyone for your suggesstion.
Free Tool: IP Lookup
I remember the day when someone asked me to create a user for an application developement. The user should be able to create views and materialized views and, so, I used the following syntax: (CODE) This way, I guessed, I would ensure that use…
Recently, an awarded photographer, Selina De Maeyer (http://www.selinademaeyer.com/), completed a photo shoot of a beautiful event (http://www.sintjacobantwerpen.be/verslag-en-fotoreportage-van-de-sacramentsprocessie-door-antwerpen#thumbnails) in An…
This video explains at a high level about the four available data types in Oracle and how dates can be manipulated by the user to get data into and out of the database.
Via a live example, show how to take different types of Oracle backups using RMAN.
Suggested Courses
592 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
