Solved
are their other products better than Datalogic products?
Posted on 2011-09-29
7
Last Modified: 2012-05-12
I would like to purchase datalogic products to control our stock, are their any other products which more better than datalogic products?
Question by:BaderAlajmi
  • 2
  • 2
  • 2
6 Comments
LVL 18
Expert Comment
by:xtermie
Author Comment
by:BaderAlajmi
communication products, microwaves, antennas, cables etc
we are a communication solutions providers
LVL 18
Accepted Solution
by:
xtermie earned 2000 total points
Ok, so you need like a stock control software for your communication products.
Check these out as listed above.
http://www.nchsoftware.com/inventory/index.html
http://stock-control-software.smartcode.com/
http://www.waspbarcode.co.uk/stock_control/
LVL 72
Expert Comment
by:Qlemo
I've requested that this question be closed as follows:
Accepted answer: 500 points for xtermie's comment http:/Q_27361225.html#36954129
for the following reason:
This question has been classified as abandoned and is closed as part of the Cleanup Program. See the recommendation for more details.
LVL 72
Expert Comment
by:Qlemo
Author Comment
by:BaderAlajmi
ok i will look for more ansewrs by other sites
The new generation of project management tools
With monday.com’s project management tool, you can see what everyone on your team is working in a single glance. Its intuitive dashboards are customizable, so you can create systems that work for you.
Introduction: When a connection to the internet is established, there always exists a modem between the connected device and the ISP (Internet Service Provider). The Operating System (OS) on your PC controls the modem which communicates with the …
More and more people are using the enhanced small form-factor pluggable (SFP+) tranceivers, and speed is of utmost importance. Testing of speeds are critical to ensure that the devices will meet the speed requirements. There are some testing challen…
Are you ready to place your question in front of subject-matter experts for more timely responses? With the release of Priority Question, Premium Members, Team Accounts and Qualified Experts can now identify the emergent level of their issue, signal…
594 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
