Is there a simple way to make parts of an animated GIF transparent?
I have an animated GIF that I'd like the background to be transparent.
I have photoshop, paint, Macromedia Flash, a PC and a macbook. The background is white.
What are my options?
Thx
beavoidAsked:
jaxbrianConnect With a Mentor Commented:
here is a snipit that I found related to your problem with Photoshop 4.0
Only "full colour" images can use layers. GIF images can't have layers in Photoshop (except the "Background" layer), the "mode" must firstly be changed (using the Image - Mode) from "Indexed Color" to "RGB color" or "CMYK color" – if that has not already been done.
Paint cant do it that I know of. it may be time to upgrade your version of Photoshop if you are going to be editing more photos than just the one. I am using Photoshop 12.1
jaxbrianCommented:
you should be able to open the gif in Photoshop and remove the background and then re-save it as an animated .gif.
if the image is not complex you can use the wand to remove the background on all layers. if it is a bit more complex you could use the pen tool to remove the background.
you will get better results if you use the pen tool, IMO
beavoidAuthor Commented:
Thx
I can make a new project with a transparent BG.
How might I remove the BG on the original?
How do I select it?
The pen tool draws a black pixel.
How do I flip through the layers? / frames?
Or, will doing it on one, do it on all?
Cloud Class® Course: Ruby Fundamentals
This course will introduce you to Ruby, as well as teach you about classes, methods, variables, data structures, loops, enumerable methods, and finishing touches.
jaxbrianCommented:
When I open gifs in Photoshop it shows all the frames as layers. I believe since gif supports a transparent background you should just be able to remove the background.
The pen tool is used to create a path. The black markings that it is making is just letting you know it is there. start tracing the outline of your image with the pen tool when you connect the the original starting point. you will then click on the "path" next tot he "layers" tab. save the path and then select it, select inverse and remove the background.
You will have to do it on all layers.
How do I view all the layers?
Is it like a flipbook?
If I press F7, there is only one layer.
I can't find a way to isolate any of the frames! It is as if it insists there is only one frame, when it is clearly animated, when opened.
jaxbrianCommented:
what version of photoshop are you using?
It's weird
The layers panel has only one layer, I can't get it to single frames.
jaxbrianCommented:
some of the versions and views can layout gifs differently. what version of Photoshop are you using?
4.0
Okay, I'll accept that as a solution in a short while. Lastly -
I think, what I'll do is if my game gets looking good enough, I'll go to ImageMonster nearby and get them to convert it and make it all look totally pro - transparent image, etc - not as expensive as a new photoshop!
I'll use the non-ransparent image like a place-holder, meanwhile. ?
