Avatar of farcuri
farcuriFlag for United States of America
Connecting a voltage output to a 1762-IF4 (Rockwell Automation PLC) Analog input card generates unexplained offset
I have a situation where I am connecting a sensing device to the input of an 1762-IF4 non-isolated input card to a PLC. The output of the device is a voltage output, where the output varies from 1 to 5V based on a corresponding input. The output of the device is faily low impedance (2k ohms).  The card input is a fairly high impedance (200k ohms) which is measured at the differential inputs. The offset can reach up to 200mV, but diminishes once the output is above 50% of scale. The offset is still present even when the analog input module is removed from PLC power.
When the device is powered and not connected to th PLC no offset can be observed.
HardwareEmbedded Hardware
Dr. Klahn
Avatar of Dr. Klahn
Dr. Klahn
Hardware
Hardware
Hardware includes cell phones and other digital living devices, tablets, computers, servers, peripherals and components, printers and scanners, gaming consoles, networking hardware such as routers, hubs, switches and modems, storage devices and security equipment such as firewalls and other appliances.
69K
