Avatar of Dustin23
Dustin23Flag for United States of America
Will statically assigned clients within a DHCP scope cause a problem?
All clients in my environment are currently configured statically.  I am in the process of converting to DHCP on my Windows Server 2008 server.  What I am wondering is, if I enable a scope within the same network, will the remaining statically assigned clients conflict with DHCP?
Windows Server 2008DHCPTCP/IP
Dustin23
Avatar of sjklein42
sjklein42
YES!
Avatar of BCipollone
BCipollone
I was always told to set static IP's outside of the scope.
Avatar of sjklein42
sjklein42
Avatar of JohnGrunwell
JohnGrunwell
No, the static ip's will be labeled as used to the rest of the clients using DHCP.
JohnGrunwell
Also If you have a list of the static ips to computers you can also create reservations if you plan to use IPv4
Avatar of Dustin23
Dustin23
@ all
Wait, so yes or no?  I am not planning on leaving the static addresses permanently.  It would just be while I am working to switch the entire network over to DHCP...
Avatar of sjklein42
sjklein42
I believe that by default, there will be conflicts, since the DHCP server assumes it has control over the entire range and does not (by default) verify that an address is free.
But if you Enable address conflict detection on the Windows Server, that should allow you to keep the fixed IP address machines going without conflict.
Avatar of Dustin23
Dustin23
@ sjklleion42
Ohh, ok I see.  I will give this a try and see what happens.  Thanks for the input!!
Avatar of Dustin23
Dustin23
This worked!!  Enabled Address Conflict Detection and once DHCP was turned on the existing static addresses were not affected.  Thanks!!
Windows Server 2008
Windows Server 2008
Windows Server 2008 and Windows Server 2008 R2, based on the Microsoft Vista codebase, is the last 32-bit server operating system released by Microsoft. It has a number of versions, including including Foundation, Standard, Enterprise, Datacenter, Web, HPC Server, Itanium and Storage; new features included server core installation and Hyper-V.
86K
