CEHJ
Connection 'going away' problems
ERROR 2006 (HY000): MySQL server has gone away
No connection. Trying to reconnect...
Connection id: 4688
Current database: foo_bar
is the constant complaint of this db. I mean the query succeeds but that phenomenon is at least irritating. How to stop it?
Perhaps it's something to do with the settings? Please see attached file.
vars.txt
Connection id: 4688
vars.txt
>>This problem is often because you have to small resources to run the Mysql server
I have around 3GB ram, plenty of disk space and the dbs total about 225MB in size. The version is 5.0.92-community
But this is a sample configuration that might help
[mysqld]
port = 3306
socket = /tmp/mysql.sock
skip-locking
key_buffer = 384M
max_allowed_packet = 64M
table_cache = 4096
sort_buffer_size = 2M
read_buffer_size = 2M
read_rnd_buffer_size = 64M
myisam_sort_buffer_size = 64M
thread_cache_size = 8
query_cache_size = 32M
This can also be a problem that you are running a to old version of Mysql with a 3:d party application (like drupal perhaps?) that require a more modern version of Mysql then you are running
Hope it helps
//Karl.
