Avatar of Eindoofus
Eindoofus
Need help converting Color.RED to a String, and String "Blue" to a Color.BLUE Color object
I need help with the code for converting Color.RED into a String, and also for converting a String such as "Blue" into a Color.BLUE Color object.
Java
CEHJ
Avatar of CEHJ
CEHJ
Java
Java
Java is a platform-independent, object-oriented programming language and run-time environment, designed to have as few implementation dependencies as possible such that developers can write one set of code across all platforms using libraries. Most devices will not run Java natively, and require a run-time component to be installed in order to execute a Java program.
102K
