Vontech615
Sonicpoint Wireless connection problem
My company has installed a new Sonicwall 2400 network security device and we are also putting in a SonicPoint Ni access point. Setting up the SonicPoint is pretty straightforward as detailed through this article: http://www.brandontek.com/networking/sonicpoint-how-to/
However, we are getting intermittent internet connectivity. We've updated the firmware on both the devices. There isn't any major interference problems. We've made sure that a firewall isn't blocking packets. Also, some users can get on sometimes and not others and I have an iPhone that will not connect at all. We've called tech support and they did a packet inspection and said that everything looked fine. Can anyone with experience settnig this up shed some light on the problem?
We had trouble with iPads connecting to sonicpoints. We learned we had to disable frame aggregation. https://www.fuzeqna.com/sonicwallkb/consumer/kbdetail.asp?kbid=8091
