Difference between system monitor and /proc/meminfo
I'm monitoring memory usage in a CentOS 5.2 instance and I'm noticing a big difference between the utilization reported by the system monitor gui and /proc/meminfo from the command line.
Here's the system monitor which shows 1.4 GB free:
 screen shot
Here's the contents of /proc/meminfo which shows 378 MB free:
[ollie@testdataload ~]$ cat /proc/meminfo
MemTotal:      4044272 kB
MemFree:        378764 kB
Buffers:         10124 kB
Cached:         999056 kB
SwapCached:          4 kB
Active:        3448596 kB
Inactive:        43812 kB
HighTotal:           0 kB
HighFree:            0 kB
LowTotal:      4044272 kB
LowFree:        378764 kB
SwapTotal:     2064376 kB
SwapFree:      2064224 kB
Dirty:           24256 kB
Writeback:          20 kB
AnonPages:     2483224 kB
Mapped:          94308 kB
Slab:            94700 kB
PageTables:      34528 kB
NFS_Unstable:        0 kB
Bounce:              0 kB
CommitLimit:   4086512 kB
Committed_AS:  3647660 kB
VmallocTotal: 34359738367 kB
VmallocUsed:    271788 kB
VmallocChunk: 34359465687 kB
HugePages_Total:     0
HugePages_Free:      0
HugePages_Rsvd:      0
Hugepagesize:     2048 kB
Can someone explain the difference between the two? If I was a betting man I would guess that the command line info is the more accurate one.
BTW, this is a vwmare guest image running on a windows 2008 host.
opikeAsked:
themrrobertCommented:
I believe that from meminfo like the free command you add cached + free to get total available memory
ps, cached contains recently used programs etc in the ram so that if you run them again it runs lightning quick, this memory is technically free since if a program requests it, the memory is used, and the program will have to be run from disk the next time :)
hope i helpd
mohansahuCommented:
1 .Generally, Linux system memory is used by the kernel for two purposes: processes and file/network cache/buffers. If you look closely at the output of free, Have a look in ur free command and compare as below:
2.If you add "buffers" and "cache", and then subtract that from the "used" column, you'll get the second line under "used" (the line that starts with '-/+ buffers/cache'), which shows about 1.4G (1433.6) in use (In ur case), which matches the reported memory in use that System Monitor is reporting (it is ignoring the buffers/cached because those will go away to make room for more processes)
MS
mohansahuCommented:
Your grep against /proc/meminfo actually matches the first line's "free" column (1433.6) is close enough to 1433. -- it likely changed between the two command outputs).
MS
Linux
