REIUSA
Help with barc-ode info, how does it work?
When you have an item like a pair of pants for example does the bar-code on the label actually contain any information about the product like size, color etc. or does it only relate to a record you already have in a database.
In other words if you have 100 items of different types would a bar-code scanner help put that info in a data base or does it only help if you create a record first and associate it with the code number and then scan many of the same items?
Would something like MS Access be able to be used with a bar-code scanner?
Thanks for any help.
Is it possible to get a database from manufacturers of all their codes that lists details for the item?
Thanks for the info. I'll check out those links for the UPC database.
You might also want to check this:
http://electronics.howstuffworks.com/gadgets/high-tech-gadgets/upc1.htm
