Small Cisco 3550 Routing Problem
I have a new configuration that I am trying to get working in an Cisco 48 port Catalyst 3550.
I think I'm doing ok, since I'm a noob.
But I have one problem that alludes me.
From this configuration, I have a router with an lan address of 192.168.1.254/24 hooked up to port 48, connected to the internet
From my 3550 (telnet on console port), I can ping 192.168.1.1, 192.168.1.254, and 151.164.1.8 (external server out on the internet).
But from a workstation plugged into port #33 that receives and address of 172.16.3.129/24, I can only ping 192.168.1.1, but not 192.168.1.254, and obviously then, not 151.164.1.8.
I'm betting this is something simple and stupid.  Any help is appreciated.
Here's the config and I'll attach it as a file.
sh run
Building configuration...
Current configuration : 6369 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Main1
ip subnet-zero
ip routing
ip dhcp excluded-address 172.16.1.1 172.16.1.128
ip dhcp excluded-address 172.16.2.1 172.16.2.128
ip dhcp excluded-address 172.16.3.1 172.16.3.128
ip dhcp excluded-address 172.16.4.1 172.16.4.128
ip dhcp pool Office
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 209.18.47.61
   domain-name Office
   lease 2
ip dhcp pool POS
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
   domain-name Office
   lease 2
ip dhcp pool Cameras
   network 172.16.3.0 255.255.255.0
   default-router 172.16.3.1
   domain-name Office
   lease 2
ip dhcp pool Sensors
   network 172.16.4.0 255.255.255.0
   default-router 172.16.4.1
   domain-name Office
   lease 2
no ip domain-lookup
spanning-tree mode pvst
spanning-tree extend system-id
interface FastEthernet0/1
 switchport access vlan 100
 switchport mode access
 no ip address
interface FastEthernet0/2
 no ip address
interface FastEthernet0/3
 no ip address
interface FastEthernet0/4
 no ip address
interface FastEthernet0/5
 no ip address
interface FastEthernet0/6
 no ip address
interface FastEthernet0/7
 no ip address
interface FastEthernet0/8
 no ip address
interface FastEthernet0/9
 no ip address
interface FastEthernet0/10
 no ip address
interface FastEthernet0/11
 no ip address
interface FastEthernet0/12
 no ip address
interface FastEthernet0/13
 no ip address
interface FastEthernet0/14
 no ip address
interface FastEthernet0/15
 no ip address
interface FastEthernet0/16
 switchport access vlan 200
 no ip address
interface FastEthernet0/17
 no ip address
interface FastEthernet0/18
 no ip address
interface FastEthernet0/19
 no ip address
interface FastEthernet0/20
 no ip address
interface FastEthernet0/21
 no ip address
interface FastEthernet0/22
 no ip address
interface FastEthernet0/23
 no ip address
interface FastEthernet0/24
 no ip address
interface FastEthernet0/25
 no ip address
interface FastEthernet0/26
 no ip address
interface FastEthernet0/27
 no ip address
interface FastEthernet0/28
 no ip address
interface FastEthernet0/29
 no ip address
interface FastEthernet0/30
 no ip address
interface FastEthernet0/31
 no ip address
interface FastEthernet0/32
 switchport access vlan 300
 no ip address
interface FastEthernet0/33
 no ip address
interface FastEthernet0/34
 no ip address
interface FastEthernet0/35
 no ip address
interface FastEthernet0/36
 no ip address
interface FastEthernet0/37
 no ip address
interface FastEthernet0/38
 no ip address
interface FastEthernet0/39
 no ip address
interface FastEthernet0/40
 no ip address
interface FastEthernet0/41
 no ip address
interface FastEthernet0/42
 no ip address
interface FastEthernet0/43
 no ip address
interface FastEthernet0/44
 no ip address
interface FastEthernet0/45
 no ip address
interface FastEthernet0/46
 no ip address
interface FastEthernet0/47
 switchport trunk encapsulation dot1q
 switchport mode trunk
 no ip address
interface FastEthernet0/48
 no switchport
 ip address 192.168.1.1 255.255.255.0
interface GigabitEthernet0/1
 no ip address
interface GigabitEthernet0/2
 no ip address
interface Vlan1
 ip address 10.1.1.1 255.255.255.0
interface Vlan100
 ip address 172.16.1.1 255.255.255.0
interface Vlan200
 ip address 172.16.2.1 255.255.255.0
interface Vlan300
 ip address 172.16.3.1 255.255.255.0
interface Vlan400
 ip address 172.16.4.1 255.255.255.0
router rip
 version 2
 network 10.0.0.0
 network 172.16.0.0
 network 192.168.1.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip http server
line con 0
 logging synchronous
line vty 0 4
 login
line vty 5 15
 login
end
Main1#
Main1# config.text.txt
tspeicherAsked:
JFrederick29Commented:
My guess would be the 192.168.1.254 router doesn't have a route to the 172.16.3.0/24 network.  You can add a static route for the 172.16.3.0/24 subnet to the 192.168.1.254 router via 192.168.1.1 or learn via RIP (if the 192.168.1.254 router can run RIP).
rochey2009Commented:
Does 192.168.1.254 have a route back to the 172.16.3.0 network?
tspeicherAuthor Commented:
Thanks. I will try that. It will take me about 24 hrs since i dont have remote to that device.   Thanks again.
Thank you for your quick responses. You were right on the money. I knew it was something simple that I was overlooking.
