Problem with Union - I need a help
Something very strange is happening in my query with UNION.
The first query doesn't return any value and it is ok
NumeroCp   RecNf_DtEmissao              RecVenNf_Vcto                    RecVeNf_Valor
The second query returns three lines and it is ok
0                 2011-10-20 00:00:00.000    2011-10-20 00:00:00.000     5000
0                 2011-10-20 00:00:00.000    2011-10-20 00:00:00.000     10000
BUT NOW
When I use UNION I got only two results:
Why?
select NumeroCp , RecNf_DtEmissao , RecVenNf_Vcto,RecVeNf_Valor
from recebimento_nf_venc, recebimento_nf,TipoEntrada
where  recebimento_nf_venc.recnf_sequencia =  recebimento_nf.recnf_sequencia
and REG_EA = '1389/11C' and AtualizaCpImportacao = 'S' and
TipoEntrada = Codigo and
TipoEntrada.TipoContabil = 'F' and NumeroCp is not null
UNION
select 0 , provisao.Vencimento , provisao.Vencimento,valor = case when taxadolar > 0 then round(saldopagto /isnull(taxadolar,1),2) else 0 end
from provisao , OrdemCompra
where OrdemCompra.numero = provisao.Ordemcompra
and numregea = '1389/11C'
and isnull(cancelado,'N') = 'N'
and numregea is not null
and saldopagto > 0
LVL 1
hidrauAsked:
Rajkumar GsSoftware EngineerCommented:
UNION returns DISTINCT records only. So that should be correct.
If you try UNION ALL instead, you should get all records (including duplicates)
Raj
In your case first query is not returning any result. But second query returns, which contains duplicate records
UNION filter out this duplicate records and output only UNIQUE records
Raj
hidrauAuthor Commented:
thanks very much
