Black_Flag
Dymo problems on VM machine - print settings not staying
Problem is, i'm trying to keep DYMO printer settings for all users who log into a VM session. I can set the printer to the correct setting while in vm, and it does stay there for my same user...but if i login as a new user the settings are back to the default ones.
Normally on an xp machine, i would hook up the dymo get the settings how i want, then copy the user profile to DEFAULT users and that works...but setting up a VM i cant just plug in a dymo when using vsphere that i know of? Only way i could get it to do that was doing it from my desktop.
What reg key am I looking for though...I tried your link and cant find where to find the hive.
The default user hive should be in C:\users\default\ntuser.da t.
"DYMO printer settings for all users who log into a VM session"
How are users connecting to a Virtual Machine? RDP?, VMware View?
