Tom Knowlton
Specifically for expert leakim971: jQuery -- bind method for click vs click method
What is the difference between:
click(function() {});
and
bind('click',function() {});
Also, would you mind taking a look at:
https://www.experts-exchange.com/questions/27414327/I-have-a-plugin-for-a-modal-dialog-box-tyring-to-hook-into-the-close-button-clcik-event.html
A solution has been given but I am struggling with implementation and the expert is not responding.
and
Done
thx...and I'll try to remember about posting questions for specific experts.
You're welcome! Thanks for the points Sir.
See you soon!
See you soon!
okay...I guess that makes sense...
Um, in case leakim does not respond:
Would you mind taking a look at:
