X-Cart Product Options Price Modifier Question - Adding both per piece and per order price changes.
Here is a sample product on our new xcart. http://creativeimpactsolutions.com/promo/product.php?productid=17514&cat=249
Notice the Imprint Colors dropdown. In our business, when you add a color, you also add $.035 per item (so qty*.35) and a $65 screen charge. As far as I can see, there is no way to do the second one. Any insights or thoughts how I can achieve this?
joshwebguyAsked:
re-searcherCommented:
simply change your product price from -> catalog > product (when you wanna add new product) or edit current product and change market price to 65.00 USD, and enable "shipping in seprate box" and add minimum quantity.
for example if your product's market price is 3 USD , enable shipping in seprate box option and set specified amount.
In addition if you want to add minimum product Qty without this option you can set it when you trying to add new products or edit product section -> "Minimum order quantity".
on that link i saw it which when we select second color it add some fees.
Please, tell more descriptions if you need any helps.
joshwebguyAuthor Commented:
Yes. It adds $0.35 per item (quantity) when I add a color from the dropdown... but I also need to add a flat $65 to the entire order. I'm stumped how I could accomplish this. Any ideas?
Cloud Class® Course: MCSA MCSE Windows Server 2012
This course teaches how to install and configure Windows Server 2012 R2.  It is the first step on your path to becoming a Microsoft Certified Solutions Expert (MCSE).
what's your shopping cart script name?
x-cart :)
sorry
The answer did not completely answer my question, but thanks!
