John Carney
Code that will check for AutoFilter mode before running macro, and adjust accordingly
I've tried some of the obvious online solutions such as "Activesheet.ShowAllData," but I can't get anything to work. If [BT5] is already in filter mode then the code below works very nicely. But if it isn't, then I need something that will deal with the two other possibilities:
John
AutoFilter is not on.
AutoFilter is active on another range.
Thanks,John
Sub Filter4ShortRows()
Application.ScreenUpdating = False
If [BT3] = "" Then
[BT5].AutoFilter Field:=1, Criteria1:="<>"
[BT4].Calculate
[BT3] = 1
Else
[BT5].AutoFilter Field:=1, Criteria1:="="
[BT3] = ""
End If
[BT5].Select
Application.ScreenUpdating = True
End Sub
Have a great weekend!
John
