How to do a backup and restore on SQLexpress
I want to do a backup and restore on my SQLexpress database.
Jose Bredariol
Jose Bredariol
  • 4
2 Solutions
sachinpatil10dCommented:
you can use command prompt also
Backup:
start>>Run>>sqlcmd -S.\SQLExpress
1> BACKUP DATABASE dbName TO DISK = 'path'
2> GO
Restore:
1> RESTORE DATABASE dbName FROM DISK = 'path'
2> GO
Run the above command in Sql management studio
path is the physical path on the hard disk
eg. "D:\Data\FileName"
Éric MoreauSenior .Net ConsultantCommented:
do you want to automate your backup process? check http://expressmaint.codeplex.com/
Jose BredariolPMPAuthor Commented:
Thanks all
Hire Technology Freelancers with Gigs
Work with freelancers specializing in everything from database administration to programming, who have proven themselves as experts in their field. Hire the best, collaborate easily, pay securely, and get projects done right.
  • 4
