Get Started
2004 Sante Fe door chime, dome light, remote entry and radio stopped working
AJNS
AJNS asked
on
Last Modified: 2012-05-12
My Dad was replacing the radio in his 2004 Santa Fe and was not sure of the wiring so he temporarily wired it. A piece of tape came off and a wire touched the back of the radio and shorted. The radio stopped working and I figured he blew the radio or a fuse. The radio works fine in another vehicle.
Then we noticed the door chimes do not work, the dome light does not come on when the door is open, the keyless entry does not unlock the doors and the radio does not work.
I checked all the fuses and they are good so I assume he blew something else like a relay or sensor.
Any ideas on what it could be that would control all of these things?
Thanks in advance
Watch Question
This problem has been solved!
Unlock 2 Answers and 5 Comments.
See Answers
Why Experts Exchange?
Experts Exchange always has the answer, or at the least points me in the correct direction! It is like having another employee that is extremely experienced.
Jim Murphy
Programmer at Smart IT Solutions
When asked, what has been your best career decision?
Deciding to stick with EE.
Mohamed Asif
Technical Department Head
Being involved with EE helped me to grow personally and professionally.
Carl Webster
CTP, Sr Infrastructure Consultant
Ask ANY Question
Connect with Certified Experts to gain insight and support on specific technology challenges including:
  • Troubleshooting
  • Research
  • Professional Opinions
Did You Know?
We've partnered with two important charities to provide clean water and computer science education to those who need it most. READ MORE
