troubleshooting Question
Need Help Declaring System.Data.SqlClient Objects in Visual Studio 2008
Avatar of stuengelman
stuengelmanFlag for United States of America asked on
.NET ProgrammingVisual Basic.NETMicrosoft Development
3 Comments1 Solution481 ViewsLast Modified:
I'm writing a simple Windows PC application in VB.NET using VS 2008 and the .NET 3.5 Framework.  My code is intended to simply recycle my MS SQL Error Log.  The code for my startup form appears in the code snippet.
All the commands below "Dim CMD As New SqlCommand" have a design time error.   There is a blue squiggly line under each object (CN and CMD), and when I hover over the object text, the yellow hover box says "Declaration expected."  I am confused as my first two commands (after the "Public Class frmMain" statement) declare both objects.
Any help would be most appreciated.
Thanks, Stu Engelman
Imports System.Data.SqlClient
Dim CN As New SqlConnection
CN.ConnectionString = "Server=(local);Trusted_Connection=True;"
CN.Open()
CMD.Connection = CN
CMD.CommandText = "EXEC sp_cycle_errorlog"
CMD.ExecuteNonQuery
CN.Close()
CMD = Nothing
CN = Nothing
End Class
Unlock 1 Answer and 3 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
