philschwartz
350W Power Supply vs. 600W Power Supply
I just purchased a new desktop pc (specs below) which has a 350W power supply installed in it. I have a new 600W power supply sitting on my shelf, and would like to know if there would be any advantages to installing it, if so what are the advantages?
This is the 600W power supply: http://www.ultraproducts.c om/applica tions/sear chtools/it em-details .asp?EdpNo =3255393
Processor Intel® Core™ i7-2600 Processor (3.40GHz)
Operating System Windows® 7 Professional 64-bit; Recovery Disk Included
Memory 12GB DDR3 Memory (4 slots, 32GB Max)
Hard Drive(s) 2TB SATA Hard Drive
Optical Drive 22X DVD±R/RW
Graphics Integrated Intel® HD Graphics (Dual monitor capable)
Audio 10 (7.1+2) channel Intel® High Definition Audio
Card Reader 19-in-1 Multiformat Card Reader
Networking 10/100/1000 Mb/s LAN
Input USB Keyboard & USB mouse
Preloaded Antivirus Software Symantec Norton Internet Security 2011 (30-day trial)
Ports (6) USB 2.0 - 2 front, 4 rear; (2) USB 3.0 (rear), (1) RJ45 LAN,(5) Audio, (1) S/PDIF, (1) HDMI, (1) DVI ***NOTE: DOES NOT INCLUDE 15-PIN D-Sub / VGA PORT. To connect this PC to a display with a 15-pin VGA connector, a DVI-to-VGA cable adapter (sold separately) is required.
Expansion Slots (Total) (2) PCI Express*2.0 x1
Expansion Bays (Total) (2) 5.25" Exposed, (1) 3.5" Exposed, (4) 3.5" Hidden
Dimensions (HxWxD) 13.9" x 7.1" x 16.9"
Weight 30lbs
Warranty 1 Year Limited Parts & Labor Warranty
Support Lifetime Toll Free 24/7 Technical Support!
Power Supply ATX 12V 350W
Weight 30lbs
